Wood/Steel Floor Wheel Tub Interchange
Hello,
Are stock wheel tubs for wood beds and steel beds exactly the same? I have a 67 K20 wood bed with beat-up wheel tubs. I found nice pair from a steel bed truck. Can I use these? Thanks |
Re: Wood/Steel Floor Wheel Tub Interchange
Yes. They lay over the floor and both style floors are made to come out at the same place on the surface. The difference is the wood floor cross supports sit lower to compensate for the added thickness and the front panel drops down lower since the flange goes under the floor
