A few parts F/S
4x4 Auto high hump 35.00
Big block high hump no holes 35.00 Burb middle seat 75.00 4x4 Engine cross member 40.00 Set if 5 after market clearance lights 25.00 Heater core housing with fan motor and heater core no cracks on housing 25.00 Burb filler neck 15.00 Pictures upon request . All parts plus shipping |
Jose not sure if I told you before or not but pont is looking for a clean high hump..
If pont isn't interested in the 4x4 high hump, I am. Let me know Jose.
Jose what is a "Big block high hump no holes" is the transmission hump? If it is how does that make a diffrence in the installation. I'm going to use a big block and I was wondering if I will need this part.
I'll let you know if pont takes it or not breeh .
jamis High hump no holes from factory were on 2wd trucks with big block and 400 tranny . Yes that is the tranny hump . |
Picture of clearance lights dealer after market option . Jose
jamis here is a picture of the high hump . Jose
whats the difference in the big block and the 4x4 humps couldnt they both be used for both?
The 4x4 humps have the holes for the transfer case shifter and the hole for the 4 speed shifter . The 2wd big blocks with auto did not have any holes . You could use the hump with out holes on a 4x4 but then you would have to cut out the holes for the TC shifter and the 4 speed shifter . The auto 4x4 high hump only has one hole for the TC shifter . Jose
Jose here is a picture of my cab, will the cover fit?
That is a low hump so it did come with an automatic .
Yes I knew it was auto I just wasnt shure on the hump. So if you think I have to use it and it will fit. Send me a pm on how you would like payment and a total to zip code 34120
jamis
No. That cover wont fit. Yours is a diffrent style. Yours is welded in, and the style Jose has is a "bolt in style". Darren |
Jose- You dont by any chance have a 2wd Non A/C Fan Shroud for a sbc? It would go on my 72'
PrimeredThunder no i don't have one at the moment . Jose
I did a search on the subject and found most peeps say its needed and comes stock on the BB/th400 combos from factory. |
I'm interested in the No-hole high hump if jamis or pont don't take it. 92262 zip. Thanks, Dave.
Sorry sub4rvr both high humps are sold .
I stand corrected.
Thanks for the heads up. Darren |
