I need a hood picture if you have one that's off a truck
When I removed my hood from the hinges on my 67 I saw that the rear nuts closest to the cowl were starting to pull thru the metal and the metal is all deformed. Could someone take a closer picture of that area so I can see what it is supposed to look like ? The front ones appear to be good.Thanks in advance.
Re: I need a hood picture if you have one that's off a truck
4 Attachment(s)
These pictures are of a hood off of a 72. I’m not certain if 72 and a 67 are the same in the area where the hinges bolt on. I would think that they are.
Perhaps a member that knows for certain can confirm Hopefully this helps in some way |
https://www.67-72chevytrucks.com/vbo...1&d=1677618736
Here’s the my hood 68 |
http://https://www.67-72chevytrucks....1&d=1677619300http://https://www.67-72chevytrucks....1&d=1677618958
Sorry just can’t figure the pics out. |
Thanks. The hinges are the same so I would assume that the stamp would be as well. I just wanted to make sure I was straightening something that wasn't supposed to be. Much appreciated
