3.07 gear set.
5 Attachment(s)
I have a good used set of 3.07 gears. Removed from my 12 bolt so I could install 3.73's.
$50 plus shipping from 97217. |
Re: 3.07 gear set.
Still for sale. Gears are not rusting, the setting sun added a reddish tint to photos.
Re: 3.07 gear set.
Bump for gas mileage. :waah:
Re: 3.07 gear set.
Cheap overdrive.
Re: 3.07 gear set.
Bump to the top
Re: 3.07 gear set.
To the for the new year!:ennyd:
Re: 3.07 gear set.
Bump for spring!
Re: 3.07 gear set.
Not to hijack your thread, but how do you like the change in the gearing. I am looking into possibly doing the same gear change. Did you see a large drop in mileage? Hope about off the line pep.
Good Luck with the sale. |
Re: 3.07 gear set.
I really like the 3.73's. Much better off the line. I didn't check the mileage when I had the 3.07 gears but I gotten high as 14.4 mpg with the 3.73's without the OD and in the 15 mpg with the OD. I don't remember there being much difference in mpg when I swapped gears.
