2000 silverado fuel pressure
what is the pressure at key on and idle. I have 45lbs does not go up with rpm. 5.3 eng.
Re: 2000 silverado fuel pressure
Key on, 2 second prime = 55-62 psi
Key off, 10 minute bleed off = 5 psi or less You have a weak pump. Replace with GM only or you’ll be doing the repair again in a few months |
would this low pressure cause a miss fire?
As said above 58-60 psi no matter what the rpm. It's an electric pump not like a small block mechanical fuel pump.
Low fuel pressure could very well cause a miss fire. Any codes via the check engine light? |
it could have a bad fuel pressure regulator on the fuel rail also
changed the reg with a new ac delco one no change. also have a 0300 code idles rough. have a new delfi pump i guess its time off with the bed.
The Delphi pump is indeed the one to buy. Aftermarket pumps tend to fail shortly. |
changed fuel pump no change of fuel pressure still 45# have not changed fuel filter tried but couldn't get the lines out after u-screwing them. will take it to a shop tired of laying under the tk.
Watch all 8 misfire counters and look for cylinders that seem worse than the others.
The cylinder(s) that is or are consistently slightly worse may have leaking injector(s) |
you could be right. my scanner won't do that. miss at idle after a warm up rev it up to 2k and it's smooth running. also won't hold pressure more than a few minutes. Need to have somebody to scope it for me.
