1969 CST gas pedal needed?
Anyone have a gas pedal that has the two holes that goes into the balls on the floorboard that is in good or usable condition for sale? Mine is broke in both holes that fit onto the floorboard,
Thank you, Ron Tilley |
Re: 1969 CST gas pedal needed?
That should be a standard pedal I believe for 67-70 (or 71). They reproduce them if you can’t find an original. Save the chrome trim around it though, that’s a cst thing and I don’t believe they sell those and they can be swapped easily.
RonWT, I have a gas pedal listed in the parts section but not sure it is the same pattern as you need. I will bring it back to the top and you can check it out. The two mounting holes on the back are almost pristine, think would work well for mounting but not sure the pattern is the same?
I have one. If you pay shipping, you can have it. It is pretty new with the chrome trim. I switched to a floating pedal.
Pm sent
