Should all 4 wheels stop when you push on the brakes?
I've got my K10 up on stands because I've been working on the brakes. I think I'm done and was testing. In reverse my passenger rear spins and when I apply the brakes, the passenger rear stops and the driver's rear starts spinning.
In neutral the driver's rear spins and both stop when I put on the brakes. In drive the driver's rear spins and when I put on the brakes, the driver's stops and the passenger's starts spinning. I may be remembering some of this wrong. Is this normal? I bought this truck a year ago and drove it onto a trailer and then off before I began replacing and fixing things so I've never really drive it or and older truck for that matter. |
Re: Should all 4 wheels stop when you push on the brakes?
sounds like the brakes need adjusting, should have equal braking to both rear tires
do you have the rear brake shoes in the correct location? big shoe in back? short shoe in front? |
If the front brakes work, the rears should self adjust over time. To speed up the process, go in reverse to 10 or 15 mph and stomp on the brakes. Repeat several times. This assumes rear drum brakes.
I adjusted the brakes last week. So I must have not done that well. My process was to pull off the drums and rotate the horizontal spreader until the pads were out so far that I could barely get the drums back on and the drums felt difficult to spin forwards and backwards. It probably takes 20 lbs. of force to spin the drums. I don't have a window on the backside to adjust them without removing the drum. How can I adjust them better? Thanks. |
Make a window and use a plug like this for access to the star wheel.
https://www.ebay.com/itm/1x-GM-Rubbe...-/270941799421 |
If they have the self adj then go in reverse and mash the brakes hard
That should adj them out Your backing plate may already have the spot stamped where the hole needs to be |
Do you have the brake shoes on right.
Short shoe goes in front. Long shoe in front might cause your non lockup of the brakes. |
Do you have an adjustment tool.
Much easier to use than a screwdriver. Like this. https://www.gearwrench.com/products/...adjusting-tool |
Take a pic when you pull the drum off.
We might see something out of order. |
5 Attachment(s)
Here's the passenger rear
5 Attachment(s)
Here's the driver's side
I've got the brakes adjusted so far our i can barely get the drums off
I might pull the star wheels off, clean them up and apply some anti-seize so the self-adjusters can work (they may already but things look a bit crusty).
My limited understanding of self-adjusters is that you back up, stop and the brakes will adjust a bit each time. This assumes the self-adjusters are working. Drums should not drag when not engaged. Disks should drag just slightly. |
Everything looks normal. Pads appear to be on correctly.
A good cleaning would help a bunch. |
Ok thanks. I'll clean everything up and if that doesn't fix it I'll either replace all the components or put on disc brakes. :)
you can buy the brake spring kits..they come with everything youll need..
what were you testing? how did the brakes perform before you started your work? please don't take this the wrong way but; 1 nothing in your pictures looks remotely like it was worked on recently 2 your randomly oriented pictures with the edges chopped off are difficult to follow 3 shoe backings look dinged up / damaged in a few spots, like they're not entirely concentic can you post just one picture of each side, entire backplate in the shot, and both right side up? that would make positive hardware verification more accurate my initial observations; agree with above, severe corrosion needs to be cleaned up at all of the contact points before any expectations of proper operation those wheel cylinders look poor, the right side piston actuator stems specifically look heavily corroded at minimum remove both wheel cylinders and take them apart to make sure they're clean inside the boots, free of moisture/corrosion, and pistons slide smoothly in the bore caution in case this crosses your mind - do not actuate wheel cylinders with hydraulic system while drums are off while cylinders are off, also inspect hydraulic line connections for signs of moisture/corrosion wheel cylinders can be attacked by water through contaminated brake fluid, water intrusion through boots and piston seals, or both brake fluid is hygroscopic - absorbs moisture, that's why only fresh sealed containers should be used and old fluid flushed < 10 years for optimal performance, more frequent for most modern systems visible corrosion would more likely be environmental, operating in wet locations, high humidity climate, coastal areas, salted roads, etc. 100% of the hydralic brake's force comes from the wheel cylinder if they're working, and shoes are not frozen to the backplate and adjusted as close the drums as you're describing, they have little choice but to work when hydraulic force is applied another possible cause of the symptoms you're describing switching sides is air in the rear brake line before or near the tee have you fully bled the entire hydraulic system? probably should have asked that first but figured you'd be past that by now but just in case :) do both rear brakes hold firm when you apply the parking brake? another word of caution - do not run drivetrain at high speeds off the ground and make rapid brake applications that type of sudden stop can stress or break u-joints, pinions, gear teeth, etc. as opposed to tire resistence with weight of vehicle on the ground it's worse than locking up the brakes while driving, tire friction on the road dampens the lockup somewhat, although those same components can fail in that situation as well a smooth moderate power brake is a better way to pre-test off the ground before road testing hopefully something there rings a bell with what led you to start working on the brakes and leads you to the cause of your symptoms and the solution please keep us posted on your findings - good luck! |
nice break down!
guess you're further along than you let on in the op, sounds like you're on the right track so if I got this straight - park brake holds, hydraulic is weak in the rear, and lines fully bled several times if you're all solid up front and hydraulic system is fully pressurizing and bled, sounds like wheel cylinders when you get the rears stripped down and pull those wheel cylinders, be interested to find out what they look like hopefully all honked up because that's an easy fix and end of the (hydraulic) line of all the work you've already done new shoes and hardware and you'll be stopping on a dime good luck! |
Thanks I appreciate it. Sounds like having new components is a great idea. It feels great to fix this thing up right. |
The brake pads I picked up are thinner and the pad portion is slightly longer. Did I get the wrong pads?
