C30 with 3/4 front axle
I have a mid 80s 1ton dually with 3/4 ton front axle.
I want to run dually wheels on front with out changing too much. Can I run a spacer that centers the wheel and clears caliper. |
Re: C30 with 3/4 front axle
I put '73 C30 spindles and rotors on my '72 GMC 3/4 ton front cross member. It was a bolt on deal. I just had to put different brake hoses on it. I think up to '87 are the same. You should be able to do the same thing to your '80's front. http://67-72chevytrucks.com/vboard/s...d.php?t=829820 Post #18 LockDoc |
You say "front axle" so I'm thinking 4wd. You have a Dana44 or 10-bolt GM in front? If that's the case...
www.arrowcraftproducts.com |
I never thought about it being a 4x4.... LockDoc |
