2001 Sonoma Brakes
The MC most likely went empty due to a blown line. I replaced the line and can not build pressure. I have clean fluid at all four corners when vacuum bleeding. I bench bled the MC and still cant get any pressure at the pedal. Any help would be appreciated. I'm suspecting ABS module has air, but I don't know how to bleed that, and im pulling fluid through it to get it out the bleeders. Stuck
Re: 2001 Sonoma Brakes
I'm a newbie with these trucks and anything this new. But I think you are correct that it's the ABS module hanging you up. I ran into the same problem bleeding my son's '08 Toyota Xrunner. But I don't remember how we worked that out. Hopefully someone will have your answer
