1980 K10 Keep air pump or delete
Hello
I have a 1980 K10 350 4spd Ac truck.All my others are pre air pump trucks. I need to replace the carb. Wondering if I should eliminate the Air pump and all that goes with it. There's vacuum lines going every where. Thanks for your thoughts |
Re: 1980 K10 Keep air pump or delete
Do you have to pass a visual inspection come smog test time.
What carb are you going to use? |
Nope don't have to pass any emission tests. Thinking of just a quadrajet with electric choke.
Not a lot to be gained ripping stuff out. Looks better maybe but might cost you 10 hp at 5 grand.
Well gosh darn I worded that wrong!
Would you like me to try again? |
Delete. You won't unlock 50 hidden HP but at this age, the air pump could fail at any time. Might as well pull everything during the carb swap. Check the threads on the plug sizes needed for the manifold holes.
Thanks I know it won't change HP much one way or the other. I was more concerned with having to chase leaks in all the vacuum lines and plastic T connectors it has a lot. I didn't want to replace all of those.
Save the parts.....take a look at what a.i.r. pumps go for now, assuming you can find them, that is.
just don't bring the truck to "the people's republic of commifornia" and try to smog it, LOL. by the way I just sent in my renewal for my 80 K20 this morning $304.00:waah:
as someone else said take it off but don't throw it away. |
