350/TH350 with less than 50k on it, $325, oil pan to heads, accesories no intake inMN
Got a 350 and TH350 (might be a TH400, haven't looked close) from a 1987 Chevy Silverado 3/4 Ton 2WD. Engine has just under 50k on it since rebuild by local machine shop in redwing, truck was T-boned in front quarter, frame/body took damage, drivetrain didn't truck was an insurance wreck. Includes block/heads, PS pump, alt, AC, A.I.R. pump, A.I.R. valve, manifolds, pulleys, ign wires and water pump. Looking for $325 for pair, not going to separate if I can avoid it. Can deliver locally (general twin cities MN area) for free or $.60/loaded mile to nearby states.
Engine is healthy, pulled hard, ran fine after the accident and doesn't smoke, knock, leak or cause herpes. Transmission had no problems and shifted fine No part of the drivetrain was damaged in the accident, I also have a driveshaft I can throw in if interested. Pics: http://www.usfamily.net/web/botboy60...350TH350-1.jpg http://www.usfamily.net/web/botboy60...350TH350-2.jpg botboy60@hotmail.com |
Put me first in line...
I will PM you for you phone number...
Thanks, Chris |
