wtb rear drop springs
Looking for a set of 4" rear drop coil springs. Anybody have a set? Thanks ......Jerry:burnout:
Have new for $120.00 a set but sorry no used.
Hey Tim!! Believe it or not I was rolling through the member list trying to find your name so I could pm you on a price. Don't think I have enough $$$ to get new ones yet, but thats what I will probably have to do. Will you be coming up to the Charlotte show in early April? If I don't have any by then, I'll pick some up there from you. I'll be in touch before then to let you know. Thanks, .......Jerry
Still looking for a set of used ones in good shape...............
i am also looking for 5" rear drop coils. :burnout:
Bamm sent you a pm
Bamm let me see what the drop is on a set that I have... If I recall correctly 1 set is 2" drops and the other is 4" drops will send you a pm when I can confirm the distance. Shane
i'd settle for 4 if you have them...and nobody else has dibs. :D
has anyone tried chevelle springs to lower rear? if they work I have a set of drop coils, new in box cheap!!!!!
I had heard of that, but haven't seen anyone come forth with any before and after pictures. If anyone has ever used Chevelle rear springs for a drop, give us some info. Exactly how much of a drop did it give you? How much less is the load bearing tension or whatever the term is for how much the spring collapses when you put something in the back of the truck. I don't want to render my truck totally useless to save a few bucks on a set of springs. What year chevelle springs can you use?
drop springs
I have a set of 4" rear drop and 2" front drop used coil springs just removed from 69 chevy pickup, $100. plus shipping, they need to be painted. I also have a set of 4 original coil springs.
Walter - pm sent
