-   The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=11)
-   -   700r4 (https://67-72chevytrucks.com/vboard/showthread.php?t=8915)
fabricator 02-08-2002 11:45 AM
700r4
I just bought a 89 blaser with the trans out. Was wondering if you guys had luck rebuilding these autos. I heard horror stories about the 700r4. Should i try to find a used one or get this one rebuilt.
firestarter_88 02-09-2002 08:53 PM
Hey, I have an 88 GM...and when my tranny went i got a rebuilt used one...they still cost lots..like i paid 1400 CAN installed..
unless you can do the work urself..then just buy the parts and rebuild it urself
gchemist 02-11-2002 07:18 AM
Have a tranny built by a professional. I had mine first stock rebuilt again because a planned 400+ HP 350 SB. Find a local shop that has a good reputation. Just ask round town. I had a beefed up 700R4 for $1100. I could have gotten it for $650 but I wanted an all out tranny. Here is break down of my the parts: 13 vein pump, 5 gear planetary gears (stock have 4), extra 3/4 clutches, valve body shift kit, Corvette servo, beefed up reverse gear and extra wide band. I also use a 24000 GVW external transmission cooler. Use cooler. Heat is the major reason these transmissions fail. A 85+ core can be rebuilt with all the stuff need to survive in a Blazer.
If you need parts I bought a Vette servo from here www.bulkparts.com
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/
[This message has been edited by gchemist (edited 02-11-2002).]
