Two part question about my heads, and 383
I was just about finished with my engine. I have every thing bought, all machine work done. all that needs to be done is assembly. At the last moment I decided to go with a different set of heads. I was going to use the alum L-98 vette heads, bigger valves installed, and ported and polished. I am thinking about going with a set of Dart pro 1 alum heads with 200 cc intake runner.
this is what I am building if some one would run a dyno useing both heads. 383 10.3:1 compression 5.7 inch rod Comp cam Hydrolic roller 276 advertise duration .502 lift intake side .510 lift on exhaust side going to use 1.6 roller rockers Eld air gap intake 750 holley dp I would like for some one to run numbers useing both set of heads, the L-98 heads I have flowed 227 on intake side, can not remember what the exhaust side flowed. I can get these heads at a really good price, just not sure if it is worth it or not, the Dart Pro 1's have not been ported or polished, they are straight out the box. Right now I have the L-98 heads ported and polished ready to bolt on. I am looking at buying some Dart pro-1's. If I go on ahead and do this, I am going to port and polish these Dart heads my self. My question is, ( I think I already know the answer ) when I am through porting and polishing, are these heads going to have to have another valve job? these heads will be brand new out the box. Is there any thing I can use to put around the valve seat to keep them from getting hit with the porting and polishing tool? So I won't have to have the valve regrind? Sam -------------------- Sam |
The only Dart Pro 1 airflow file i have is for the 215cc heads, with 2.05/1.60 valves. Running through small tube headers and mufflers, i came up with this (very impressive IMO)
rpm hp tq 2000 160 421 2500 206 433 3000 254 444 3500 307 461 4000 358 469 4500 403 470 5000 432 453 5500 444 424 6000 434 380 6500 409 330 7000 372 279 With a pair of L98's with 2.02/1.60 valves (i increased intake/exhaust flow by 10% for the porting, proably not accurate) rpm hp tq 2000 165 432 2500 213 447 3000 261 458 3500 314 471 4000 362 476 4500 405 473 5000 432 454 5500 441 421 6000 428 375 6500 398 322 7000 358 268 Remember, this is a computer simulation and not entirely accurate by any means. I would think the Dart 215's would make more power, because the flow is pretty darn good (269/174 @.600" lift). |
227" is enough to support 467hp.....price is right too!!:cool:
Either way, alum. heads would be good with that compression ratio. |
your cam is a little mild to run the pro 1 heads. i would stick with the vette heads. not only would the motor have more torque but they are already done. i don`t know what experience you have porting heads or if you have a flow bench but if you don`t have either one, i would`nt port the pro 1 heads. they cost to much to ruin if you don`t know what your doing.
