disc brake conversion
Hello all,
i am new to the forum. i was wondering if there is any information on how to covert my 69 blazer from drum brakes to disc brakes. any information would help. thanks! Ct |
If it is a 4x4, I would get the complete front axle of the same gear ratio from a 71 up through 77, (I believe). The brake lines/hoses will have to be changed as well as the master cylinder. You will need the prop valve also.
Jim |
IF IT IS 2WD, I HAVE A COMPLETE CRADLE/SUSPENSION SET-UP
WITH DISC'S FROM A 72 LONGBED PICK-UP RIMS AND ALL. :D |
