Old 04-01-2023, 09:59 PM   #51
ThreeQuarter
ThreeQuarter's Avatar
Re: ThreeQuarter's 1968 C10 Build Thread
I've been noticing a vibration that coincided with road speed (not engine speed) but the frequency was higher than tires/wheels/brakes would normally produce. I had been running the original driveshaft for the time being, so I decided it was time to replace it with all new parts. No dice.
I started looking into driveline angles and it turned out that my factory setup was pretty bad. All of the u-joint angles were around 2.5deg (reasonable), but the arrangement of the angles was not ideal. After some measuring, drawing, and calculating, I ordered 1/2" worth of transmission mount spacers, 4deg axle shims, and some new axle u-bolts (because I had cut my existing ones to exactly the right length). The results were very satisfying! That vibration is gone and I can ride easy now knowing my u-joints aren't aching.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 05-01-2024, 11:44 PM   #52
cericd
cericd's Avatar
Any updates on this beautiful truck?
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 05-02-2024, 10:44 PM   #53
ThreeQuarter
Hey Chris, thanks for checking on me. I haven’t been on the board much lately because there hasn’t been a lot of work getting done on the ‘68. Been driving it some—just turned 5K miles on Monday, which is not as much as I intended to drive it. Still need to get HVAC installed. At some point I just gotta prioritize it and get it done!
Ben
Old 05-02-2024, 11:24 PM   #54
cericd
cericd's Avatar
Glad to hear that it's getting some drive time. I need to get mine our more now that we're back in Texas. Years ago I bought some original style base trim level black vinyl seat trim from SMS but haven't had the seat recovered yet. I probably should've let them make the cover. Yours turned out great! Excellent work on the painted pine bed floor. I almost never see anyone go that route. It makes me wish my truck had a wood bed to restore. To me, nothing looks better than one of those body colored wood bed floors.
Where did you get that vintage cruise control kit? I'll bet it makes longer drive much more enjoyable.
Can't say enough good things about your truck, just love what you've done with it.
Chris
Old 05-03-2024, 11:15 AM   #55
68Gold/white
Ben,
Good to hear from you. I hope you all are good!!!
Any of those tornados close to you?
I'm guessing you are still in Iowa?
Jeff
68Gold/white is offline   Reply With Quote
Old 05-03-2024, 11:30 AM   #56
Shifty One
Shifty One's Avatar
Gorgeous....there are about a million words I could use, but gorgeous seems to cover it...
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 05-03-2024, 11:38 PM   #57
ThreeQuarter
Aw, shucks—thanks guys! I’m happy that I’m so happy with it—not too many regrets on doing it the way I did.
Chris—I’m very pleased with the quality of the SMS seat cover. It goes a long way in completing the original experience. My cruise is a kit that came from Roger Koop here on the board. He’s in KC and I’ve visited him a few times and also had him restore my vent windows. When I got this close to the end of the project (and being the cruise control addict that I am), I decided to splurge a little on cruise. There are a few things I allowed myself to not “cheap out” with (paint, stainless windshield trim, seat foam & upholstery, cruise) and so far I have no regrets in making those calls.
Jeff—how’s is going in OK? Tornadoes all around but not at my house, thankfully. Two layoffs and I’m still in Iowa. If you had tried to tell me 15 years ago I’d still be here, I would’nt have believed you. But Iowa has some good things going for it. Winter’s not one of them.
Thanks, Shifty! GM did all the heavy lifting, I just colored inside the lines they drew.
Ben
Old 05-12-2024, 04:49 PM   #58
LT7A
Originally Posted by ThreeQuarter View Post
Glad to hear some appreciation for the build. And thanks for the advice on the belt webbing. It's probably one of those things that only bothers owners and concours judges.
I got the chance to catch up on your truck and am glad to see you keeping the theme of 99+percent stock. It looks great.
I agree with your comment on the seat belts. I don't think they would stand out to the casual observer. If they do bug you, as the owner, as you said - I did see that Rit makes a gray dye that could darken/dull them a bit. Move them toward the insert color. Don't mind me - I'm a detail guy and pondering this for my own belts. Mine cleaned up in general so nice that now you can really see the stains, haha.
