Old 01-04-2010, 03:10 PM   #1
a55togo
a55togo's Avatar
frame swap?
does anyone know off a frame swap for the 55-59 trucks? all these s10 swaps on the 47-53 trucks has given me ideas,lol
Ed
a55togo is offline   Reply With Quote
Old 01-04-2010, 03:29 PM   #2
blackdiesel
blackdiesel's Avatar
Re: frame swap?
Ed
they have been put on several different frames. an easy one that comes to mind is a blazer, 80's model. Something with a flat frame. you can also take a long wheel base pickup frame from that same body style and cut the step out of the frame and flip the rear axle to compensate for the difference. i've seen them on 67-72 frames. If a man knew what he was doing and wanted a real work horse he should get him a good cab and slap it on a 94-98 dodge 12 valve cummins chassis with a flatbed on the rear. that would be a cracker jack of a truck
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 01-04-2010, 03:50 PM   #3
a55togo
a55togo's Avatar
Re: frame swap?
i was going to make it a 4wd, already have the stuff to do it, but now i am leaning towards bein on the ground with power steering, and a safe ride unlike the stock straight axle,lol
Old 01-04-2010, 04:12 PM   #4
blackdiesel
Re: frame swap?
i would go with the original frame and an aftermarket independent front suspension then. much simpler than trying to rig it up on another frame
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 01-04-2010, 08:57 PM   #5
T Hilde
Re: frame swap?
you need to look this over
http://67-72chevytrucks.com/vboard/s...d.php?t=233305
T Hilde is offline   Reply With Quote
Old 01-04-2010, 09:05 PM   #6
bigdsr56
bigdsr56's Avatar
Re: frame swap?
I recently sold a '58 Chevy Fleetside that I'd put on a '73 Chevy truck frame. Was a easy swap. Just measure everything twice. Took cab mounts off of '58 frame,drilled holes on '73 frame & bolted cab down with new '58 cab mount hardware kit.
bigdsr56 is offline   Reply With Quote
Old 01-05-2010, 10:35 AM   #7
pugs
pugs's Avatar
Re: frame swap?
im hoping to pick up another 55 cab GMC cab by next week and im gonna set it up on a 64 chassis, will be an easy swap
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 01-05-2010, 01:34 PM   #8
a55togo
a55togo's Avatar
Re: frame swap?
thanks for th link, very resourceful, I think I am going to stick with the 4wd conversion
Old 01-05-2010, 03:30 PM   #9
pugs
pugs's Avatar
Re: frame swap?
do you still plan on the feame swap and go 4x? what i would is try to find an earlier model with the str8 axles and convert your original frame to 4x which would be easier and you can still add ps to the truck by using GM parts
Old 01-05-2010, 05:29 PM   #10
a55togo
a55togo's Avatar
Re: frame swap?
use the stock 57 frame with 77 chevy pick up front rear axles and transfercase,steering box, and even the 77 transfercase cross members, i have all the stuff to do it now its just finding the time to do it, as it is an outside project, not to mention on a budget.
Ed
Old 01-05-2010, 07:07 PM   #11
pugs
pugs's Avatar
Re: frame swap?
well it sounds like you the important parts covered to get started
Old 01-14-2010, 03:18 AM   #12
heavy_chevy
heavy_chevy's Avatar
Re: frame swap?
That is some good info. I just purchased my 55 stepside 2nd series on sunday and the guy want to sell me a 73 pickup that has just the cab on it, but has all the suspension to use to restore it. I am not sure if it worth it to buy for 150 bucks and swap over or just clip the front. Any suggestions
heavy_chevy is offline   Reply With Quote
Old 01-14-2010, 05:23 AM   #13
a55togo
a55togo's Avatar
Re: frame swap?
is the 73 a 4wd or 2wd?
Old 01-14-2010, 03:32 PM   #14
hotrodsbyray
Re: frame swap?
Anybody ever considered a Chevy Colorado frame? At one time I did some quick measurements and if I remember the dimensions were close. I got a cheap subframe so am going that way. With all the problems I have run into I have to wonder if I should have tried a swap instead!
hotrodsbyray is offline   Reply With Quote
Old 01-15-2010, 04:47 AM   #15
a55togo
a55togo's Avatar
Re: frame swap?
haven't heard of anyone doing that with a colorado. bad part is they are six lugs if I'm not mistaken and up until this year they didn't come with v8's so you would have to fab some motor mounts. but hey, it might work
Old 01-18-2010, 04:41 PM   #16
heavy_chevy
Re: frame swap?
It is a 2wd. It has the disc in the front and drums in the back.
