10-04-2017, 06:24 PM | #1 |
Speedeometer
Speedometer 92 g20 van to fit stock cluster. Does anyone have the email of the guy on here that makes them? Thanks guys
Posted via Mobile Device |
10-05-2017, 10:57 PM | #2 |
Re: Speedeometer
Welcome aboard, ls1nova71 did the thread on using a stock 96-97 s-10 speedo and making it work in the stock cluster. I haven't seen a g20 speedo used. Get with him if this is your direction. Eric (ls1nova71) does a vinyl overlay, stencil for new mph numbers, etc. He will direct you to the board member that makes a metal box that houses the s-10 speedo head. I did this mod and love it, works perfectly! Eric is a fantastic help, you are in good hands.
Good luck, and no matter which speedo you use let's see the progress. As a little info, if you intend to do a 8,000 rpm tach get that first before you modify your cluster lens. Last edited by 68c10airstream; 10-05-2017 at 11:17 PM. |
10-06-2017, 02:58 AM | #3 |
Re: Speedeometer
Ahh, definitely. I built my electric speedo cluster then thought man I should have done a 8k tach but after all the work in the lens I think I'll just stick with the 5k on this one but.... may get a wild hair to build another with the 8k
