07-20-2020, 06:27 PM | #1 |
Need a little help on 5.3 wiring
Put a running driving 2004 Tahoe 5.3 in my 72 K5 from a 72 K20 donor. The removal was not as clean as I'd like and I lost some of the prior connections. Here is a picture of my wiring and any help filling in the blanks as to what goes where would be appreciated. Also does anybody make a inspection cover for a 5.3 to a TH350 or do I have to fab one.
07-21-2020, 08:55 AM | #2 |
Re: Need a little help on 5.3 wiring
lt1swap.com if you're not aware of that site already.
Orange typically is constant 12v. The white on the right side could be tachometer signal. |
07-21-2020, 11:42 AM | #3 |
Devote a lot of time on LT1swap.com. The information is there but you have to dig. I learned that EVERY link in a paragraph leads to something else. Explore stuff you think has nothing to do with your swap. Info is everywhere.
It's not set up like a traditional website with tabs or a navigation pane on the left. Just pages with writing that have RED links to other pages. Still, great info. Without it I would have never been able to do my swap. Brendan also does PCM reprogramming. I sent mine to him and worked right off the bat.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
07-21-2020, 11:53 AM | #4 |
Thanks I'll dig into that site some more. Anybody on the inspection shield ? Also where are you running your wire bundle through on the firewall and what type of grommet. The prior vehicle had everything mounted on the fender and I'm thinking more sanitary in the glove box area
07-21-2020, 12:01 PM | #5 |
I used the 4L60E so i don't know about the inspection cover. For my 85, I used the stock fuse block for a lot of the standard wires. There were plenty of other additional access holes I reused for other items.
07-21-2020, 12:36 PM | #6 |
I did my firewall hole behind the drivers side head..that way it wont interfere with hvac stuff...
Itll be a fairly large hole to get all the wiring and connectors thru...I used psi harness,,it comes with the grommet....you might contact one of the harness places...they may sell the grommets.. Heres a few ... https://www.bp-automotive.com/produc...ewall-grommet/ https://www.speartech.com/product_p/grommet.htm
07-21-2020, 05:48 PM | #7 | |
07-21-2020, 06:27 PM | #8 |
These work good for large bundles through the firewall. Made by Seals-it.
