08-12-2016, 10:13 PM | #1 |
Top 5 performance mods that won't blow my motor.
I am getting a 327. It's probably tired and I want to get it to about 400 to 425 horse and about 450 lb foot of torque.
1: is this unreasonable? 2: how much will I be spending. Including rebuild. 3: what are the 5 top performance mods you would add first. Thanks! -G |
08-12-2016, 10:18 PM | #2 |
Re: Top 5 performance mods that won't blow my motor.
1 HP/cubic inch is fairly doable with your 5 mods request.
1 - Headers 2 - Cam 3 - Intake 4 - Carb 5 - Decent ignition For the numbers you want you might consider a off the shelf motor. By the time your do all the machine work and parts to rebuild yours you might be money ahead to buy a ready to go engine.
71 Blazer 4X4 (unmolested, all original (including paint) 74,000 mile barn find) 67 Camaro RS SS (unmolested, all original (including paint) 81,000 mile barn find) Keith Riel |
08-12-2016, 10:20 PM | #3 |
Okay. That does make sense. That was sorta along the lines I was thinking of. Thanks cat.
08-12-2016, 11:11 PM | #4 |
Good cylinder heads are important. praisegeetarman 1 HP per cubic inch would only be 327 HP. I do agree a crate engine would probably his best option
Boyd -67' C10 SWB FLEETSIDE LS 5.3 4 speed muncie |
08-12-2016, 11:34 PM | #5 |
I will tell you first hand you'll be dumping some serious cash. I just built a 331 (327 bored .030 over) for my 65 Nova gasser. I started with a tired block, did machining, went with full rollers (cam, rockers, lifter), tunnel ram with dual quads, edelbrock performer rpm heads, plus all the accessories and I'm pushing about 500 hp. But I will tell you that my cost for parts and machining (as I did the assembly myself) was close to $5,000. Yes my Nova will run low 10's in the 1/4 mile and redline at 7,500 rpm...but going fast costs money period.
Customization is what you want it to look like -- not what other people think it should look like |
08-13-2016, 08:28 AM | #6 | |
I changed his up a little but right idea.
08-13-2016, 08:38 AM | #7 | |
08-13-2016, 10:17 AM | #8 |
Getting a small block over 400 hp is more of a challenge then a lot expect. I'd recommend doing a lot of research before you start buying stuff. Make sure your heads flow good, make sure your Intake is set up to be good in the same rpm range as your cam.
I built a 383 stroker, pushing 600 hp. Part matching, balanced and blueprinted is a must when wanting to turn high rpm's or producing high hp's. A 327 pushing 450 hp is very do able, just take your time and do research and make sure your parts work well together. |
08-13-2016, 01:08 PM | #9 |
Okay. I'll hold off. Thanks guys for the info!
08-13-2016, 01:23 PM | #10 |
Aim for 300hp or move to the LS platform. It'll take some serious cylinder heads to get near 400 usable horsepower on a 327, I think.
Maybe a better option is not shoot for any number but just take the upgrades on in a reasonable order and keep them working with each other, so: Carb and intake Headers and Exhaust Cam Heads (etc)
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
