01-06-2024, 10:13 AM | #1 |
Chev-odge: 71 K20 Cummins build
Welcome to the build of my Chev-odge. I’m Rob and I’ve always wanted a Cummins diesel truck and I wouldn’t want anything else except a 67-72 Chevy to house it in. I am thankful for this site and the resources it contains as I certainly will be needing them, and you. Thank you for your input and help ahead of time. Enjoy the fun and struggles with me that this will bring…and hopefully we’ll see a great outcome at the end.
So to start things off, here’s the 1989 5.9 Cummins I purchased with 400,000 miles. With this, I received the 5 speed Getrag transmission (no transfer case), the front and rear differentials (with 3.08 gears I am told, not verified), the driveshafts and to me, one of the most important items…the front clip of the Dodge. Right now my goal is to use the factory Dodge crossmember (with mod and fabrication) in the K20 frame. I think using the Mopar mounts will be slick. Has anyone else used a Mopar cross member? If so, what was your experience? Last edited by fishnixon; 01-06-2024 at 01:21 PM. |
01-06-2024, 10:54 AM | #2 |
Re: Chev-odge: 71 K20 Cummins build
Sounds like fun, Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
01-06-2024, 11:19 AM | #3 |
I will follow along.
Here are a Few threads. Link: https://67-72chevytrucks.com/vboard/...hlight=cummins Link: https://67-72chevytrucks.com/vboard/...hlight=cummins Link: https://67-72chevytrucks.com/vboard/...hlight=cummins
01-08-2024, 10:36 AM | #4 | |
01-08-2024, 10:35 AM | #5 |
01-06-2024, 06:47 PM | #6 |
Looking forward to seeing the build.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
01-06-2024, 11:24 PM | #7 |
Me too, this will be interesting!!
01-08-2024, 10:38 AM | #8 |
01-08-2024, 11:08 AM | #9 |
Im calling in reinforcements. Jim and John (father and son), know what to do
they do this for a living.👍
01-08-2024, 11:11 AM | #10 |
The stand is holding!
01-08-2024, 10:37 AM | #11 |
01-08-2024, 03:14 PM | #12 |
Active Member
Awesome build, I'll be following along. Do you have the K20 already?
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
01-08-2024, 03:51 PM | #13 |
01-09-2024, 04:04 PM | #14 |
Brought some parts home to clean up and prime
the pistons are home for good as they wont be used. Were going .020 over on the block.
01-09-2024, 06:17 PM | #15 |
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
01-10-2024, 01:16 AM | #16 | |
01-26-2024, 11:11 AM | #17 |
Active Member
Awesome progress
01-27-2024, 12:34 PM | #18 |
01-31-2024, 12:53 AM | #19 |
great project! curious about new rods vs getting the old ones rebuilt?
72 Chevy C20 Longhorn 72 Chevy, K20 Custom Camper 67 Chevy, LWB, C20, 350/350, PS, PB, 65 Jag MKII |
02-04-2024, 02:31 PM | #20 |
Cool build!
Good choice to go through the Cummins now I have a Chevy-Dodge too. Built it in 2003 using a rolled over 02 Dodge. I used the entire drivetrain and chassis on mine- been using it for over 20 years.
71 C10 72 K20 72 K10 Super Kirk |
02-12-2024, 01:04 AM | #21 |
Thank you, Ive always wanted one
how difficult was it to put the Chevy on the Dodge chassis?
02-12-2024, 01:08 AM | #22 |
Back at it
I wanted to locate the position of the 350s harmonic balancer vs the frame, which then I can use in locating the Cummins.
02-12-2024, 01:12 AM | #23 |
I also made a note of where GM locates the engine cross member and will measure the distance from the center of the mounts to the front of the balancer, and compare that to the Cummins mount location
Ill attempt to use the Mopar crossmember and new mounts on the project.
02-22-2024, 10:44 PM | #24 | |
You’re making good progress!
02-24-2024, 01:21 AM | #25 |
Nice! 4 months is not too bad at all
I hope to get things rolling nicely by then. Thank you!
