10-17-2021, 09:43 AM | #1 |
73-75 vs 76-77 bucket seats
Could an expert on blazer bucket seat help me with the differences.
I know the top is shaped different visual....I would love a list of differences ..all differences ..I’m having a hard time with two sets of seats I have Thanks
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD 73 k5 gm crate 350-265 / sm465 / np205 3.73 posi |
10-17-2021, 11:35 AM | #2 |
Active Member
Re: 73-75 vs 76-77 bucket seats
Yes 73-75 foam is different shape then 76-77. Not sure if actual frames are different but I do know one difference is gonna be the rear bolt hole spacing is different, 73-75 is spaced at 3.75 inches and 76-77 is spaced at 5 inches. The only time this becomes an issue is if your trying to set up the seats in a truck with truck brackets. If your using k5 brackets to go into a blazer than it doesn’t apply as that 2nd inner bolt hole isn’t used. Besides that I believe the seats are identical
What exactly are you trying to figure out to do? If you have a set of 73-75 seats and want to trade for a 76-77 set I have 3 nice pairs. |
10-17-2021, 03:33 PM | #3 |
Thanks for the reply
I’ve got two complete sets of seat and brackets. the later brackets and seats are in better shape and I would rather use them but the holes in the floor of my 73 k5 seem off. I know that the seats are blazer seats I took them out..Plus to complicate it I have distintive industry seat covers ordered for the early seats. I’m trying to cobble one set out off parts
10-17-2021, 03:53 PM | #4 | |
Active Member
10-18-2021, 09:39 AM | #5 |
subscribed
Larry 84 Chevy SWB, "Roy", dark blue orig paint, 6 cyl auto, PS, 88,000 miles. 72 Highlander LWB "Olive" med olive over lt yellow, air, 77,000 miles (sold) "It's a sorry man who can't find his wife a good job" |
01-31-2022, 05:31 PM | #6 |
I saw your post on TCKR's thread and thought I would ask here - instead of there - about the differences between 73-75 and 76-77. If you would post some pics of what you got that would be great, there is insufficient info out there regarding squarebody buckets, IMO. What you have could be helpful.
I was lucky enough to score some "medallion" style buckets that I now know are 76-77 seats, but my goal is to reupholster them into 73-75 versions. I am wondering if there is any reason I could not simply refoam and recover them, or if there is some structural difference that means I should abandon this idea.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
01-31-2022, 06:14 PM | #7 | |
Active Member
Let me know if you try this. I have multiple sets of 76-77 and would like one more of 73-75 style. |
01-31-2022, 10:37 PM | #8 |
Active Member
If there was a difference in the frame I would think it would be at the tops where on the early style it’ll be more narrow than the later style
02-01-2022, 11:42 AM | #9 |
I have striped both set down (73-75) and (76-77) as far as I can tell there is no difference in the metal frames. The bolts in the frames line up with my hardware also.
I have ordered 73-75 seat foams and covers but have yet to install. I can say with a 95% confidence you can make 76-77 seat frames into 73-75 seats. I will add the 5% when they are covered.
02-01-2022, 12:21 PM | #10 | |
Active Member
03-03-2022, 11:21 AM | #11 |
Just to follow up with this thread.....76-77 low back bucket frames are basically identical to 73-75 ....I used 73 covers from distinctive industries, 73 foams, and 76 frames.....they look like they are supposed to
03-03-2022, 11:54 AM | #12 |
Active Member
03-03-2022, 12:35 PM | #13 |
Here they are. I dig the two-tone, even tho it wasn’t an original option.
03-03-2022, 12:45 PM | #14 |
Active Member
Reid those look awesome and you did a great job. In regards to your rear seat, is it a 73-75 style with the curved 2 point armrest bars?
03-03-2022, 12:52 PM | #15 |
Thanks!!!
Yes it is the type that bolts at the rear, and at the front bottom
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD 73 k5 gm crate 350-265 / sm465 / np205 3.73 posi Last edited by ky-donzi; 03-03-2022 at 02:39 PM. |
03-05-2022, 03:34 AM | #16 | |
I hope to get those results for my 73 frames in my 1973 GMC Sierra Grande shortbox My seats were super rustfree and non ripped original covers but may rethink using the oriiginal foam now. Got your same brand covers on order in black but where did you get your foam? Thanks for help! Love it. Mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
03-05-2022, 09:24 AM | #17 |
Hotfun
I got them here https://www.profitautointeriors.com/...iABEgLxIPD_BwE They weren’t cheap, but at the time they were the only vendor that had them.....also they say with wires, but there were no wires in them Reid
03-05-2022, 12:14 PM | #18 |
Active Member
How hard is it to apply the foam assuming the frames are stripped and clean? Do they just glue down to the frame?
03-05-2022, 03:16 PM | #19 |
Oh, I might have mislead you...I didn’t put the covers on...I had a shop do them. ....I delivered to the upholstery shop the repaired frames (needed welding) the new covers from distinctive industries, the old original covers, the new cushions and the old cushions.....and some pics of what they are supposed to look like....and said fix this....lol
With that said the cushions just kinda set there....he may of put a tiny amount of glue on the, but they are an excellent fit and would stay on there own
03-05-2022, 03:59 PM | #20 |
I was thinking maybe I should try it those look so nice. My original foam is such good shape no holes tears and is nice and supple. Just want them to fill out the cover as nice as what you had done. Looks like those covers are PUI brand with wire and a few places have them or closer delivery estimates. Thanks Ill post mine when they get here in June or so. lol
