04-28-2024, 07:32 PM | #1 |
Rear shock crossmember same as 67-72?
Does anyone make a new rear shock crossmember as seen here? I can't use a tubular because the QA1 rear sway bar for their coil-over kit uses this crossmember to mount the sway bar mounts to it. This one is in pretty bad shape.
I see that the 67-72 looks really close to the 66 style.
My mother is a recent cancer survivor and this truck build is for her |
04-29-2024, 09:56 PM | #2 |
Re: Rear shock crossmember same as 67-72?
It's the same from 63-72 on that part, I'm fairly certain.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
04-30-2024, 02:39 PM | #3 |
Here is some dimensions that you can check to your crossmember.
Link: https://help.classicindustries.com/e...ons-of-t677207
