11-25-2020, 07:03 PM | #1 |
2 more ‘67 GMC brake questions....
1. Are the wheel cylinder pistons reusable?
2. Where can I find two of the washers that fit under the front cylinder bolt? (pic below)
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense |
11-25-2020, 07:29 PM | #2 |
Re: 2 more ‘67 GMC brake questions....
For the cost of the wheel cylinders I usually buy new ones there like 6 bucks at rock auto
11-25-2020, 08:12 PM | #3 |
I bought new ones but they didn’t come with the pistons or those washers....
11-25-2020, 08:21 PM | #4 |
Who Changed This?
You bought a rebuild kit, then? I've never seen a wheel cylinder that wasn't complete with new pistons. Please post a picture. If you actually bought the cast iron body of the wheel cylinder, somebody dog-robbed the innards.
11-25-2020, 09:48 PM | #5 |
Cast iron body, rubber covers, and innards. Maybe piston is the wrong word - I’m referring to the things that stick out from the cylinder and bear against the brake shoes.
11-25-2020, 10:29 PM | #6 |
If you mean the short push rods like these in the link then yes reuse them.
https://partsavatar.ca/1963-1967-chr...SABEgI6cfD_BwE |
11-25-2020, 11:27 PM | #7 | |
Who Changed This?
11-25-2020, 11:38 PM | #8 |
Thanks for the replies!
Any suggestions on my second question regarding the washer?
11-26-2020, 11:00 AM | #9 | |
The Older Generation
Ace or any other good hardware store should have a specialty washer with those inside and outside dimensions. (maybe even the big box stores) Just grind the side off and put a little paint on it to keep it from rusting. After you get it all together just tap the washer over one of the flats on the top of the anchor bolt to keep it secure. You can actually start the bend in a vise before you put them on. LockDoc
11-26-2020, 11:17 AM | #10 | |
11-26-2020, 12:34 PM | #11 |
You may be able to find one in the drawers of hardware and look in the BUSHINGS not washers. You might have luck
11-28-2020, 04:41 PM | #12 | |
Thanks!
11-28-2020, 07:31 PM | #13 |
I looked at my semi-local Theisens farm store. It looks like those washer type bushings would work but I didn't have the inside dia. measurement with me. LockDoc
