11-11-2017, 08:23 PM | #1 |
So what are your plans for heating your garage this winter
I bought this dyna glow pro a few years ago from one of the local pawn shops for $100.00 I replaced the ignitor box (like $15.00) after about a year and since then it's worked perfect ,Auto thermostat will keep it nice and toasty at 72 all week for about $12.00 Using diesel
11-11-2017, 08:50 PM | #2 |
The Older Generation
Re: So what are your plans for heating your garage this winter
I used one of those for a few years. When I moved and built a bigger shop I put in a hanging LP heater and so far it works great. LockDoc
11-11-2017, 09:39 PM | #3 |
I have a hanging propane heater that is set to 50(mainly to keep the pipes from freezing). If I want it warmer than that, I get the wood stove going.
Those torpedo heaters work good, but the fumes burn my eyes and puts a funny taste in the air. |
11-11-2017, 10:07 PM | #4 |
I have a propane jet heater. It heats well, but since my garage isn't insulated it has to run almost constantly. It's really loud, too.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
11-11-2017, 10:30 PM | #5 |
blood type; Retumbo
I just open the door between basement stairway and garage. Attached garages are nice.
If I limit use of overhead doors my garage stays just above freezing. Good for slush melt and great for deer carcass seasoning
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
11-11-2017, 10:58 PM | #6 |
I installed this around this time last year. I pretty much only fire it when I know I'll be out there for a while.
Getting familiar with how it works I burned about 30 some gallons through it last year. I learned if I keep the thermostat set around 50-60 seems to be the comfortable Hoodie/flannel wearing sweet spot. I still keep my loud stinky turbo heater around for back up though.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
11-12-2017, 08:20 AM | #7 |
I have a pot belly wood stove and a kerosene heater. Now I need a shop. I used those in the barn shop I used to have and just used the wood stove. I ran conduit pipe across the work bay (ways separated bays) at about 8' and laid cheap blue tarp across for a ceiling. You could see light through the corrugated tin walls but it plenty warm in there
11-12-2017, 11:24 AM | #8 |
"Tail Gate Best Seat In House"
I will use my 4 foot tall on casters 45000 watt radient infrared heater, , I added blown in insulation to the attic and that gave me some 10 degrees warmer than out side ...
This 220 volt heater will either warm an area only where you are working or in time it will heat up the whole garage.. I have not done this yet ,but from using it before when I had a shop ,,it did keep and area pretty warm ... but I had to move it to where ever I was working and that some times was kinda a nuicense .. If I figured it correctly ,,I should be able to have this heater turned on all day for 8 hours for some where around $3 @ 8 cents a KW https://photos.app.goo.gl/EfSUKFN0m7sy0i0k1
When you learn a thing a day you store up smart. Last edited by GOPAPA; 11-12-2017 at 11:37 AM. |
11-12-2017, 03:50 PM | #9 |
A hanging gas heater. My shop is insulated with spray foam, so not hard to heat. 65' is my working temp.
11-12-2017, 04:14 PM | #10 | |
When I lived out in Oregon we had NO gas heat ,,all electric and Cheap too.. so when I moved here I had a sale before and after arriving and no one wanted a electric heater that I paid $300 for in eather local.. So now ,,,I am glad it didnt sell as it is going to work out just right here ..electric rates are around 8.5 I think and for the enjoyment of being able to work on my 39 durring the snow days will be just fine. I'm the second Larry I think
When you learn a thing a day you store up smart. |
11-12-2017, 06:18 PM | #11 |
I use a 30k BTU natural gas ceiling mounted unit in my 24x30. I found leaving it on 50 and turning it up when I'm in there works best. Gas bill was $200 for entire winter last year
11-14-2017, 02:23 PM | #12 | |
11-14-2017, 03:33 PM | #13 |
Location: Formerly MD and San Diego, now loving life in Arizona
Don't have a usable garage, so I guess I am stuck...oh wait, I live in SE Arizona, no heat needed!
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
11-14-2017, 04:15 PM | #14 |
I try to use uninformed in-laws whenever possible.....no shortage of hot air to accompany the range of nonsensical ideas and opinions.
lol Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
11-14-2017, 10:23 PM | #15 |
My shop has a propane overhead radiant tube heater and temp is left at 50 degrees all the time. Working temp is usually 60 degrees which with radiant heat is really comfortable.
11-15-2017, 02:12 AM | #16 | |
Best response yet Coley
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
11-15-2017, 10:32 AM | #17 |
I installed a forced air furnace when I first built this a few years back. We actually lived in a portion of my shop when finishing up the house build so it was "necessary". It makes for a comfortable environment lol
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
11-15-2017, 10:45 AM | #18 |
I'll do what I always do....dress warmly and stay out of there unless I need to get something or store something away.
11-15-2017, 12:26 PM | #19 |
11-15-2017, 01:06 PM | #20 |
Old member
My garage is all insulated so I normally just use a spot electric heater. It works pretty good when you choose what days to work temp wise.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-15-2017, 02:46 PM | #21 |
I'll be working ON the house all winter this year.
For some reason I hate working in the garage with the door closed, so if it's below 45-50*, it can wait until next week We have pretty mild winters here... if it's not at least 50 one week, it will be next week.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
11-15-2017, 04:43 PM | #22 |
This little jewel heats my 3000 sq ft with ease. We have several through the wall package units that we salvaged from a government job. I should put one of those in and sell the rest.
11-15-2017, 07:24 PM | #23 |
Who Me?
Nothing needed here i'm happy to say..
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
11-15-2017, 08:44 PM | #24 |
After working in 3 different repair facilities for almost 30 years and i was the only one to check on the health of the free hanging gas heaters and finding that after as little as 3 years the heat exchanger would be rusted out from the inside out i said i was going to do something different for MY shop. I installed a new SEALED COMBUSTION hot air furnace. It's been 25 years now in service and an occasional dust blow out and filters changed it works like new and no rusted out heat exchanger. It's a counter flow (down flow) mounted on a 2' high metal box with three sides covered and the hot air blows out on the floor. Works awesome.
If you look at a grainger catalog they have a note saying " no warranty for these heaters mounted in an environment with fumes, solvents, etc, creating what is called halogenated hydrocarbons". Another words, if warm inside shop air is being used for combustion and bad fumes are present it will rot out the heat exchanger. My rant is from 3 shops, 3 different owners, and carbon monoxide poisioning noted and discussed with all 3 and it fell on deaf ears. I offered free labor to install a replacement SEALED COMBUSTION heater after hours to limit business down time and was turned down every time. The last owner pissed me off enough that i left the auto repair field 3 weeks later and go to the power industry. Now retired with a pension and health benifits i should thank him. I'm posting this to inform you guys that the great working heater hanging near your ceiling (and they do work great) may poison you or kill you, so take a moment and get a ladder out and look at the back side where the fan is and when it's lit and heeating look at the vertical sections that the fan blows on and check for cracks and you may even see the flame glow shine through the cracks. This area is the coolest because of the fan so it condenses inside the metal exchanger and that mixes with the fumes and creates acidic sweat. Do you use carb cleaner? brake cleaner? Laquer thinner? Enamel reducer? Have children that can visit your grave site?? Dealing with asthma, fighting with owners for a proper repair, feeling tired in winter and coming home exhausted falling asleep on the living room floor with my coat on for 2-3 hours, maybe i can save one truck forums life!! Enough of my old man rant, but you have now been informed. |
11-15-2017, 08:51 PM | #25 |
So true.
Any gas fired heater should be inspected at least annually, and carbon monoxide detectors should be in place.
