11-22-2004, 11:04 PM | #1 |
blower fan problem and question
Hey Guys, I need your help. I am not sure what part needs to be replaced or what needs to be fixed, but here is the issue. When I turn the fan switch (with A/C model) to first on position i can hear the blower fan bearly turning, second position blower fan turns fast enough tp push a little air out the vents, but not as fast it did last week, and the thrid position (Hi) the blower fan turns off. Is it the motor, switch, or speed resistor? Is there a way I can test each part?
Thanks in advance for your help, Blake
Blake 72 Blazer, 350, tubro 350, NP205, 32x11.5x15 http://home.comcast.net/~blakesara/K5Photos.htm Last edited by Blake_72_Blazer; 11-22-2004 at 11:13 PM. |
11-22-2004, 11:05 PM | #2 |
Ac?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
11-22-2004, 11:12 PM | #3 |
Sorry I forgot to state, with A/C.
Blake 72 Blazer, 350, tubro 350, NP205, 32x11.5x15 http://home.comcast.net/~blakesara/K5Photos.htm |
11-22-2004, 11:18 PM | #4 |
Sounds like the resistor to me. You can check your motor by hooking it to 12v. If it runs full speed, it's ok. you can also take the plug off the resistor move the switch and check for voltage at the pins with a meter. If it's an AC truck, AND if memory serves, the switch has a 'triangle' shape plug. Seems like pwr came from the brown wire and went to orange, blue and yellow. you could take the plug off and use a jumper across the brown (could have been black -- don't have a print in frount of me) to the others and if the motor works, you'd have a bad switch. Let me know if you continue to have trouble.
Bobbi |
11-22-2004, 11:22 PM | #5 |
Plain forgot about the relay. There's a relay on the far side of the pletum over on the passenger side. be sure to check it also. It can cause problems too.
Bobbi |
11-22-2004, 11:41 PM | #6 |
I just had a similar situation. Although mine is without AC, it was a $6 resistor that caused my problem.
Bret
71 Custom 20 Deluxe..soon to be SWB 1/2 ton 1 incredible wife 2 great kids |
