08-09-2020, 01:54 AM | #1 |
Advice on tire size and 3-4 drop
Brothers Truck catalog recommends a 3 front drop and a 4 rear drop; they have coil springs for the drop; 1963 C20.
I am going with 16 rims instead of the 16.5 stock wheels. Would like to get some recommendations on tires size and if the 3 front, 4 rear drop will work for my truck. Pros/cons? The pic shows how my truck looks sitting with the stock 16.5 wheels and tires. Seriously considering the purchase of these springs and doing this drop What do you guys think?
1963 C20, small window, long bed 292, 4-speed |
08-09-2020, 09:43 AM | #2 |
Re: Advice on tire size and 3-4 drop
Most of us are only accustom to dropping half tons myself included. If it were a half ton I would encourage you to use drop spindles in the front as 3 inches removes the majority of your suspension travel essentially putting it on the bump stops. 4 inches in back will have some effect on shock angle and stroke but would be just up to the limit of where you would need additional mods....remember whether its a half ton or bigger.....the lower you go, the more $$$ you need to spend to do it right.
08-13-2020, 05:36 PM | #3 | |
Do you like their size or would you do things different if given the option? That being said, I would keep the rear spring as tall as possible & go w/a lowering block for some of the drop (2" drop coil + 2" blocks). Yes, it's slightly more expensive but it helps keep the shock angle changes to a minimum.
08-13-2020, 07:07 PM | #4 | |
What do you think?
08-13-2020, 07:56 PM | #5 | |||||
YOU need this info to make an informed decision. Without it, you're buying generic parts. Quote:
The rears for the C10 generation trucks are typically 2" higher vs. the front. So, 'level' drops typically follow those numbers: 1/3; 2/4; 3/5; 4/6; 4/7". A 2/3 drop could yield a slightly noticed rake ESPECIALLY w/different size F/R tires.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-13-2020 at 08:07 PM. |
08-13-2020, 08:00 PM | #6 |
Sounds good. It will bring it down without it looking "obviously lowered" and you will still be able to slide under it for impromptu repairs. You coluld always add a block kit to the rear later if you decide you want it down a bit more.
08-13-2020, 09:35 PM | #7 | ||
Another truck I saw for sale has a 2 / 4 drop, and to me, it doesn’t look right. Attaching a pic of the catalog page and the other truck. That truck has the 2/4 drop and front 205-60-16 and rear 235-60-16.
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 08-14-2020 at 02:34 AM. |
08-13-2020, 10:04 PM | #8 | |
If you like that truck & it's using Brothers parts then go for it.
09-07-2020, 03:49 PM | #9 |
What do you guys think of using a P-rated tire on the C20? I know if I go into a tire shop they would say, that tire doesn't fit your truck. I just do not want an all-terrain tire on my truck. And, I'm not that worried about the speed rating, its not like I will be doing 80-90mph on the freeway.
So, I'm thinking of just picking up four 235/60-16 tires - what do you guys think?
09-14-2020, 06:18 PM | #10 | |
I'm thinking the 235/60-16s will look too small, they are 3" less in diameter than the stock tires. I guess I could look for some used tires, for the mean-time, just to get it rolling and see how she drives. Maybe the 70 or 75 series tires would suffice. I'm just worried about getting a 60 series tire and it looking weird with the gap between the fender and tire. Might look goofy. What do you guys think?
09-07-2020, 05:13 PM | #11 |
My '66 and '64 half tons have P235/75/15 tires and P225/35/15 tires. I've always understood the "P" to mean "passenger vehicle so always figured it's okay because I just pretty much use them as such. Every now again I might haul a load to the dump but nothing too heavy. I suppose I were going to work it harder I would step up to LT but I have a 2017 Silverado for the hard work
09-07-2020, 05:31 PM | #12 |
One more thing Mr. Hat, as to the Brothers 3/4 recomendation....i would be more concerned about removing 3" of travel from the front springs than 4" out back. My half ton has a 2" drop spring in front and it does hit the stops now and again. I wouldn't want an even shorter spring because there just simply isn't enough travel to spare.
09-07-2020, 05:35 PM | #13 |
I have P tires on my truck right now. I'm not sure if it's my lead foot, P tires on a half ton truck, or a combination of both that seems to have worn the tires out much quicker than they should have. Probably a combination of both, but I'll be going with a light truck tire next go around. I also don't want an A/T tire as I don't take the truck off road enough to justify them. I do a lot of street miles and a fair amount of highway miles with plans to do more highway miles once I get some A/C in it, so I'll be going with a LT highway tire
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
09-07-2020, 09:40 PM | #14 | |
1965 GMC 910 Short Fleetside. 230 CI 4-speed. |
09-08-2020, 12:34 PM | #15 |
I've studied and measured for new wheels and tires for weeks. I have finally found the right combination for me. I've got 17"x8" wheels and the tires are 225x50rx17 and the rears are 245x60rx17. I've got the wheels and the front tires arrived yesterday. Not mounted yet. The rear tires will be here Friday. I have 2 1/2 inch drop spindles and 1" drop springs in front and 5" drop springs in back.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
09-14-2020, 07:17 PM | #16 |
I agree with you. I'm old school with my classics and I like the tires to have a decent sidewall. I tried the big wheel small tire thing once on a Tacoma. The ride sucked and the tires wore out quickly. I sold "em after that and put the factory ones back on.
09-15-2020, 05:57 AM | #17 |
I have 235/75/15 on my truck with a static 3" drop. 3" springs in rear and dialed down torsion up front. The rear wheel arch is about 1" above the whitewall. It has a nice stance I wish I had done the 4" drop.
09-16-2020, 05:02 PM | #18 |
Installed a 3/5 drop on my 64 C10, spindles in front and coils in rear along with shock relocation brackets and a C notch. Just put the wheel on it to see what it looked like after finally getting the bed back on. Will be running 235/60/17 soft 8s or D windows on it....havent decided quite yet which one.
The one pictured is a 15x8 rally with 235/70/15 so should be near identical height to my new wheels/tires.
1964 C10 Resto-mod 5.3L - L59 Last edited by Justin71105; 09-16-2020 at 09:10 PM. |
09-20-2020, 08:47 PM | #19 |
Picked up some tires yesterday, 236/65-16. Rated as an LT tire.
Didnt drop it on the ground yet, still need to get the exhaust squared away. Thinking about powder coating the hubcaps red.
09-25-2020, 10:15 PM | #20 |
This thing has been up on jack stands for months. First time hitting the floor with the tires and wheels. Going to try and drive it tomorrow, and get some better pics.
09-26-2020, 01:27 PM | #21 |
It starts up, with choke real quick. Idles well. Major noise from driveline. Sounds like the driveshaft maybe? Cant really tell.
And, the motor smokes when accelerating. When it was idling it also smoked, but it didnt seem like it was coming out of the tailpipe. I think most of the smoke at idle was oil burning off the manifold, had a valve cover gasket leak. Guess its time to pull the drive train.
09-26-2020, 03:16 PM | #22 |
Nice! If you have a 2 piece drive shaft, good chance the carrier bearing is taking a one way trip to the scrap heap
09-26-2020, 04:03 PM | #23 |
I did replace that, but the u-joints are pretty old. Maybe I should drop the trans and replace the clutch too.
09-27-2020, 08:16 PM | #24 | |
Definitely gotta drop the transmission.
09-27-2020, 09:24 PM | #25 |
Throw out bearings make noise when you press in the clutch. How is the oil level in the trans?
