10-14-2022, 03:41 PM | #1 |
Dg4 Mirror bolts
Are the Dg4 mirror Bolts reproduced?
10-15-2022, 04:57 PM | #2 |
Active Member
Re: Dg4 Mirror bolts
Did you try LMC?
Don Brace 55 Nomad 56 Nomad 58 Impalla Coupe 58 Bel-Aire 4D HT 61 Impala CVRT 409 4 SP 2- 71 Longhorns Always looking for old toy trains, Juke boxes Pin ball and game machines. |
10-16-2022, 12:45 AM | #3 |
The original DG4s on my '69 did not use "bolts". They (pic attached) were what I'd refer to as large hex head sheet metal screws. the threaded portion is 3/4" long. The head takes a 3/8" socket. The threaded portion diameter is slightly less than1/4". So, I assume a 3/16" hole may have been used. The the mirrors bolted directly to the paint... no washer of any kind. Unless you are striving for complete originality, you may want to consider using the method GM used on vans around the late '70s for mounting the large outside mirrors (the second pic).
Jim Last edited by FirstOwner69; 10-16-2022 at 01:12 AM. Reason: Added second picture |
10-16-2022, 05:50 AM | #4 |
A good thread on the mirrors. https://67-72chevytrucks.com/vboard/...&highlight=dg4
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
