Old 12-22-2010, 04:09 PM   #1
jorgensensc
jorgensensc's Avatar
Need some measurements please.
Okay, so I'm trying to figure out how to make something work on my '72 burb. Any help would greatly be appreciated!
For the second row I need the measurements for the distance between where the bracket ( u shaped bracket that holds the seat back in place) on the side of the seat back mounts and the side of the interior cargo panel. I'm trying to see if I can use that setup on my seat, but I'm not sure my seat is as wide as the square body burb second row seat.
Also can I get the height of the second row flip seat bracket from the floor to where it mounts on the seat bottom?
One last measurement. The distance between the second row leading edge and the back of the front seat.
Thanks in advance, I appreciate it. I know it can be a pain.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 12-22-2010, 07:06 PM   #2
Mkcustums
Mkcustums's Avatar
Re: Need some measurements please.
Shawn
Hey Shawn, are you trying to make your middle seat fold down? I might be missing something but I'm not sure what you're trying to do.
Mkcustums is offline   Reply With Quote
Old 12-22-2010, 07:30 PM   #3
jorgensensc
Your not missing a thing. That is exactly what I'm trying to do. I am tying to see if the setup off the squarebody burbs might be able to work. I can make the stock seat back flip down, so if I can find a way to secure it in the upright position, then I just need to flip the whole seat forward when I release the seat back to lay on the bottom cushion. Again hopefully using the brackets off the squarebody burb.
The third row seat will be a different animal altogether though.
Shawn
Old 12-23-2010, 02:04 PM   #4
jorgensensc
Is anybody available to bust out a tape measure and check those measurements for me? I would be very grateful. It will help me figure out what I need to do to make this happen.
Shawn
Old 12-23-2010, 02:49 PM   #5
Mkcustums
Mkcustums's Avatar
I'm out of town for a while so I wont be much of any help. If I see one at a lot or something while I'm out I'll see if I can get ya some measurements. My sister has a nice '72 but her interior is all leather out of an '03 I think, but if I see her I'll take a peek and see how hard it might look.
I wish you knew someone close to you that had one so you could do some side by side comparing, that would be ideal for sure!
Old 01-11-2011, 08:39 PM   #6
jorgensensc
Could anybody check this yet? I would really appreciate it.
Thanks!
Old 01-11-2011, 09:56 PM   #7
TheApocalyptican
TheApocalyptican's Avatar
Thanks!
If no one else does it for you, I should be able to sometime later in the week. I currently don't have the stock second row seats. I am carpeting and sound deadening, and once that's done the stock second row seats will be getting put in, and I could do a measurement then.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 01-12-2011, 07:44 PM   #8
ericjon262
this help?
1 1/2 inches
2 1/2 inches
I'll try to get you the other measurement tomorrow.
'06 2500 HD 4x4. manual transfer case, crank windows.
'88 V10 Suburban 4x4,"The Pig Rig" L05, 700r4, NP208, 4x4 beater camper fun truck project.
My trucks don't leak oil, they mark their territory.
ericjon262 is offline   Reply With Quote
Old 01-13-2011, 05:04 PM   #9
jorgensensc
Thanks! That helps alot!
Shawn
