08-17-2004, 11:45 AM | #1 |
GO VOLS!
Some progress
Almost ready to start it up and break in the cam. (the air filter is just sitting on the carb, still have to get my own)
408 BB (402 bored 0.030" over) cam specs: valve lift, int. 0.503", exh. 0.528"; duration @ 0.050", int. 214deg, exh. 224deg; 112deg lobe spread. Edelbrock Performer dual plane intake Harland Sharp aluminum roller rockers HEI w/ 50,000 volt coil Quadrajet 780cfm Speedpro pistons 9:1 compression
http://1972blazer.shutterfly.com/<= blazer build pics It's called golf because all the other four letter words were taken. It's easier to ask for forgiveness than for permission. Last edited by orangeuavol; 08-18-2004 at 10:26 PM. |
08-17-2004, 02:36 PM | #2 |
What kind of power do expect it to put out? Should motivate your K5 great.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
08-17-2004, 07:48 PM | #3 |
I am a Gov't Mule
WOW!! Does anyone have a towel or moist towelette? LOL That's awesome man!
...to die in the saddle must be my destiny, to ride this rockin' horse I must be crazy... |
08-17-2004, 09:36 PM | #4 |
GO VOLS!
output
Desktop dyno estimates about 415 ft-lbs @ 4500rpm and 398 HP at 5500rpm. Torque curve is very flat, 368 ft-lb @ 2000rpm. Exactly what I want for a 4x4...a stump puller!
Side note, my dad ran a desktop dyno on his 502 and it was very close to what GM advertised.
http://1972blazer.shutterfly.com/<= blazer build pics It's called golf because all the other four letter words were taken. It's easier to ask for forgiveness than for permission. |
08-18-2004, 06:25 PM | #5 |
Okay, what's a desktop dyno and were can I get one?
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
08-18-2004, 06:26 PM | #6 |
By the way, really sweet motor!!!!!
08-18-2004, 10:32 PM | #7 |
GO VOLS!
Desktop Dyno 2000, its computer software for estimating the horsepower and torque curves based on the specs of the engine components you enter.
Had to do some rework. Found out that you shouldn't use the stock exhaust valve rotators due the added lift of my cam. I'm having to replace them a "anti-rotator" kit. luckily we can do that with out having to take the intake and heads back off. Any of you guys want to keep 'Murphy' at you house for a while?
08-19-2004, 02:12 AM | #8 | |
http://www.sdpc2000.com/cart.asp?act...art&catid=1962
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
08-19-2004, 02:28 AM | #9 | |
RPM--------POWER(FLY)---------TORQUE(FLY) 2000-------148------------------387 3000-------236------------------413 4000-------332------------------436 5000-------398------------------418 5500-------403------------------384
08-19-2004, 08:43 PM | #10 |
I am a Gov't Mule
[QUOTE=orangeuavol Any of you guys want to keep 'Murphy' at you house for a while?[/QUOTE]
No thanx! His twin brother's been sleepin on my couch for years!!
