Old 09-04-2018, 07:12 PM   #1
Jeepnut
Jeepnut's Avatar
Pop rivets for wing window w/s?
Installing the full weatherstripping set for the vent/wingwindows. My kit is from Brothers, I believe seals are Precision. It came with the rivets and the installation tool to install the wing window seal on the window track. I attempted one rivet and it was a hassle...I know they say to use two people but didnĀ’t have anyone available and usually donĀ’t.
Question: will typical pop rivets work? The local hardware store has some that are stainless steel that appear to be the same diameter. I will still use the correct supplied rivet for the vent window pivot hinge.
Thank you
Walt
68 CST.
Jeepnut is offline   Reply With Quote
Old 09-04-2018, 07:39 PM   #2
notsolo
notsolo's Avatar
Re: Pop rivets for wing window w/s?
A Hassle, is putting it mildly...Frustrating for sure. I used small flat head bolts, I could not get the rivet to tighten up...Without the correct tool it is nearly impossible. NOT what you wanted to hear...Good luck.
notsolo is offline   Reply With Quote
Old 09-04-2018, 07:59 PM   #3
leddzepp
Moderator
leddzepp's Avatar
I’ve used pop rivets, makes it much easier. I ground down the head of the tool so it would fit in the channel and make the rivet nice and tight.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 09-05-2018, 03:13 AM   #4
Mike_The_Grad
Mike_The_Grad's Avatar
PITA FOR SURE. I overhauled my passenger wing window. Took me 3 days pulling and reinstalling. That rivet kit is no fun. They make special tools for those type rivets. They range from $90-$300. Didnt warrant a purchase for me.
Because of the awkwardness and difficulty involved. I've only done the one side window. The drivers side is in worse condition than the passenger side was.
All in all, it came out pretty good and I'm happy with it.
Here's a tip if you find yourself tackling this solo like I did.
Get a piece of 3/8" or 1/2" flat stock mild steel by about 2" wide and about as long as your window assembly or at least the width of your bench vise jaws.(you do have a bench vise right?) Place the flat stock in the vice and set it so that the vent window channel rides along the edge but high enough for the vent window assembly to NOT touch the vice jaws. It helps a lot when your setting the tube rivets by giving you a solid surface to strike the rivet setting tool with your hammer. Also, theres a great YouTube video on overhauling the vent window assembly. Its about 45 minutes long. But is well worth watching at least once.
https://youtu.be/WiZOiHmcb_w
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline   Reply With Quote
Old 10-24-2018, 11:06 AM   #5
jeff_wilson70
jeff_wilson70's Avatar
After ordering the rivet kit with the little tool. I cut the tool down and attempted to use a C-Clamp.....Also my bench vise....The rivet tool distorts and was able to press a couple of rivets.....Very frustrating.
So, I then ordered some stainless steel chicago screws typically used for leather on amazon and this was very simple. The hardest part was getting them in and around the rubber on the vertical seal. But otherwise was very simple and I used them on all the rivets including the main pivot. These tightened down nicely and my vent windows are now as good as new.
Here is a link for the screws I ordered......They are 3/16 posts that are 1/8" long.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
jeff_wilson70 is offline   Reply With Quote
Old 10-25-2018, 08:38 AM   #6
shoveldug
first time I have seen this approach. Interesting!
shoveldug is offline   Reply With Quote
Old 10-25-2018, 09:40 AM   #7
MySons68C20
MySons68C20's Avatar
Mike is right on.......a piece of steel to back up the channel makes it doable with the tool that comes with the kit. I really like the little screw idea too.
Blake
MySons68C20 is offline   Reply With Quote
Old 10-25-2018, 03:51 PM   #8
tdangle
tdangle's Avatar
I just did the drivers side last weekend. Yes it is PITA! If I had the proper rivet tool it would actually have been quite easy but not ready to spend big $ for a one time fix. I think I am going to try using pop rivets for the other side this weekend. If it doesn't work I can always use the rivets I bought with the rubber pieces.
Hint: A work surface in the middle of the floor with a vise mounted to it is much easier that a workbench against a wall.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 10-25-2018, 10:37 PM   #9
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I took a Arbor Press and drilled out the press part to hold the tool provided in the kit. Then use a piece of square stock on the back side.
Works....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 10-25-2018, 11:09 PM   #10
tdangle
tdangle's Avatar
Works....
Smitty
Thats actually not a bad idea. It would have other uses also and Harbor Freight has a 1 ton for $60
Terry
Old 10-25-2018, 11:52 PM   #11
Getter-Done
Getter-Done's Avatar
Works....
Smitty
Great idea
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 10-27-2018, 12:50 AM   #12
71meangreenc10
Yep,
I can post a pic tomorrow.
Smitty
71 C30 Wrecker
Old 10-27-2018, 12:51 AM   #13
71meangreenc10
Originally Posted by Getter-Done View Post
Great idea
Thank you!!
Smitty
71 C30 Wrecker
Old 10-27-2018, 09:31 AM   #14
Average Joe
Average Joe's Avatar
Sub'd for later reference. Great ideas guys. Thanks for sharing!!!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 10-27-2018, 08:37 PM   #15
Project86
i gave up on mine. rebuilt everything with precision seals attempted the rivet kit.
ended up using stainless steel screws and nylon lock washers.
Project86 is offline   Reply With Quote
Old 10-28-2018, 04:04 AM   #16
Montierth
Montierth's Avatar
Anyone have pics of the pop rivets or the screws? Never thought of either. I too ordered the kit but cant imagine tapping those rivets and everything tightening up properly.
1970 GMC C1500 short fleet
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 1970 GMC C2500 Dually Flat Bed
- 2003 Silverado
Montierth is offline   Reply With Quote
Old 10-28-2018, 02:16 PM   #17
rcazwillis
Finished both windows Friday. The video linked above is very helpful. Used 1/2" aluminum as described, worked really well. The rivets and tool do the job if you can get a solid backing on the head of the rivet. Also used two threaded Chicago studs to fix an error. Don't forget some lock tight.
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 10-28-2018, 02:55 PM   #18
TBONE1964
Cluster King
TBONE1964's Avatar
Zip products makes a nice rivet tool for these.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
