05-15-2021, 11:47 PM | #1 |
Pie Crust Air Cleaner on a 350?
I want this style Air Cleaner on my 350 that’s in my ‘66 C10. Has anyone ever modified one to fit a Rochester Qjet carb?
I bet it’s been done before but I’d like your suggestions and maybe pics of one that someone modified. Thanks, Michael |
05-16-2021, 12:41 AM | #2 |
Re: Pie Crust Air Cleaner on a 350?
I cut the base off one air cleaner and welded to another style..I tacked it in several places and used seam sealer to fill the gap..
05-16-2021, 06:53 AM | #3 |
Moderator
05-16-2021, 08:37 AM | #4 |
A friend of mine here locally has a nice 2bbl version of a pie crust air cleaner. It’s in nice condition and he only wants $20 for it. Just wondering how close a 4bbl version would come to working on a Qjet before I modify a 2bbl?
05-16-2021, 10:43 AM | #5 |
You can get adaptors for the smaller neck 4bbl carb to a quadrajet. Just flip them over and use a riser. You might need a riser to raise the adaptor slightly to clear linkage if needed.
Like this. https://www.summitracing.com/parts/m...SABEgKy5PD_BwE |
05-16-2021, 01:47 PM | #6 |
Here's how mine was done. Just some sheet metal formed into a tube, welded together, then trial fit until it cleared the HEI dizzy I have. If I decide to run a spacer under the carb, I'll probably cut the air cleaner base down some. Still looks fairly factory in my opinion though.
There's been a ton of changes under the hood since these pics
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-16-2021, 08:15 PM | #7 | |
05-16-2021, 09:52 PM | #8 |
A slice of 5" exhaust pipe from a semi shop will work well. Just like cw's...cut the hole until the tube slides in it, sit the tube on the carb & figure how high you need the base to to clear everything by a 1/4", draw a line around it, cut it off & weld 'er up! Lorne
CW, Thats a nice neat job! |
05-19-2021, 07:47 AM | #9 |
I can't take the credit for my air cleaner. Member Jrusk welded it up for me before I bought my welder.
I am planning on changing it up a little bit in the next couple of weeks though. I'll post a pic once I do the thing
