Old 11-28-2023, 12:12 PM   #1
landarts
landarts
1971 Jimmy Fuel setup help?
I have read and searched for three days and am still a little confused about what setup will work. Let me give you a little background on what I want to do.
I would like to use a 25 galllon 87 Blazer tank since it has a baffle in the tank. Use the 87 sending unit for that tank and install the proper fuel pump on the sending unit. I have stock gauges in the 1971 Jimmy and I know they are set up for 0-90 ohms. According to everything I have read the 87 sending unit is 0-95 ohms.
So do people just live with that incorrect reading, and change out the sending unit head from a stock 1972 sending unit that is 0-90 ohms? Is there an adapter or a better way to do it?
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 11-28-2023, 03:40 PM   #2
clay68c10
clay68c10's Avatar
Re: 1971 Jimmy Fuel setup help?
The 87 sender should be should be 0-90 also.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 11-28-2023, 11:38 PM   #3
jessemthompson
The 87 sending will work. I used this setup when I initially did my LS swap.
jessemthompson is offline   Reply With Quote
