Old 03-02-2016, 03:32 PM   #1
hayseed71
hayseed71's Avatar
no high beams
The other night i went to turn on my high beams and the headlights went out. I figured it was the dimmer switch so I just replaced it. Could it possibly be the headlight switch? Low beams work as does the panel dimmer and dome light. It just seems a little unlikely that both high beams would burn out at exactly the same time.
hayseed71 is offline   Reply With Quote
Old 03-02-2016, 04:03 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: no high beams
If you replaced the floor switch, verify that you have power going to the headlight high beam wires. Could be a broken wire, loose connector. Headlight switch does nothing in regards to the high/low beams, it just gives power to the floor switch and the wiring to the headlights.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-02-2016, 04:22 PM   #3
hayseed71
hayseed71's Avatar
Re: no high beams
I did some more checking and both high beams are blown. Tested the dimmer switch and when on high it has a short to ground. So the switch blew both bulbs. I didnt think the beadlight switch had anything to do with high or low. Thanks for the input.
Old 03-02-2016, 06:28 PM   #4
Brad54
Brad54's Avatar
Re: no high beams
I hate electrical gremlins...
I had the contacts come out of the Bakelight headlight switch housing, and they bounced around inside the housing, eventually crossing the wrong thing and shorting wires.
The result was some of the wires going to the dimmer burned up, as well as other wires under the dash.
I had headlights, no tail lights, intermittent brights, and the turn signals and brake lights worked.
Oh, and I discovered that in the rain, in the fall, a burning wiring harness smells just like the burning leaf piles people put in the ditch next to the road.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 03-02-2016, 06:49 PM   #5
hayseed71
hayseed71's Avatar
Re: no high beams
Yeah this truck has a few gremlins. At some point in time i will probably rewire the whole thing. Right now the left turn signal blinks a little faster than once per second and the right blinks about once every 1.5 seconds. Has to be some excess resistance somewhere. Ahhh the joys of buying an old truck.
Old 03-02-2016, 07:20 PM   #6
Backpayne
Re: no high beams
Same thing happened to me; both high beams went out at the same time. I checked everything else before I checked the actual lights.
Backpayne is offline   Reply With Quote
Old 03-02-2016, 07:22 PM   #7
hayseed71
hayseed71's Avatar
Re: no high beams
Sometimes I forget to use the K.I.S.S. principle.
Old 03-02-2016, 07:26 PM   #8
jayoldschool
Moderator
Re: no high beams
Lights are on my "to-do" list in the Spring. The parking lights work, the headlights... no. I had to hurry home a couple times as the days got shorter last Fall!
jayoldschool is offline   Reply With Quote
Old 03-02-2016, 07:29 PM   #9
hayseed71
hayseed71's Avatar
Re: no high beams
That could turn into a bad situation. You could always run a temporary setup through a toggle switch and relay. That way you wouldnt have to worry about being caught in the dark.
Old 03-03-2016, 02:36 AM   #10
sanford66
sanford66's Avatar
Re: no high beams
Check out the wiring connector plug at the dimmer switch on the floor. These are notorious for going bad. Mine did the same thing and I found the plug had worn through against the floor board and was shorted to ground. I could jiggle the wires and get the high beams to work off and on. You will have to find a good used plug off another truck because these aren't being reproduced. I went through 6 of my parts trucks before I found a good one. Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 03-03-2016, 11:29 AM   #11
TJ's Chevy
TJ's Chevy's Avatar
Re: no high beams
It was a ground issue when I had that problem.
Old 09-20-2020, 11:40 AM   #12
rrbaker15
Re: no high beams
My son and I just purchased a 1972 GMC C15, headlights were working and somehow the high beam were turned on as we could not figure where that switch is, is the switch the same for GMC as it's for Chevy?
Update: the previous owner had the floor switch hidden behind the rug, not sure why but we discovered that the dimmer switch is giving us flimsy results so will investigate to see if we need to replace or other not.
rrbaker15 is offline   Reply With Quote
