Old 06-05-2023, 08:36 PM   #1
twotrucks
Junior Member
Engine to frame ground
Looking for a picture or diagram of engine (small block) to frame ground connection. Any help is appreciated. Thanks
twotrucks is offline   Reply With Quote
Old 06-05-2023, 09:33 PM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Engine to frame ground
This is how I ground my motors...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 06-05-2023, 09:38 PM   #3
twotrucks
Junior Member
Thank you, Ironangel.
Old 06-05-2023, 09:47 PM   #4
Ironangel
Ironangel's Avatar
Your welcome! I have a spool of that stuff so I make my own. Never hurts to add a strap to the fender and the fender to the cab. Cant have to many grounds...
"Two Seventy Two's"
02 3/4 ton Express
Old 06-05-2023, 11:18 PM   #5
Sheepdip
Sheepdip's Avatar
No Truer Words Spoken! 90% of electrical problems are grounding issues.
Sheepdip is offline   Reply With Quote
Old 06-07-2023, 10:19 AM   #6
72SB
I bought straps on Amazon and put them where the FSM showed for a 6 cylinder
72SB is offline   Reply With Quote
Old 06-07-2023, 04:45 PM   #7
LS short box
As said above you cant have too many good grounds. I go from battery to engine block. Then engine to frame with heavy gauge cable.
Then frame to cab on both sides with 6 gauge cable using ring terminal and heat shrink.
Then radiator to frame with 6 gauge like the cab.
Then frame to box for good tail light grounds. Also if you have a rear mounted gas tank/fuel pump they need good grounds.
My builds are LS swaps and they demand good grounds.
Old 06-07-2023, 07:49 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
Back when I was having hot start problems, one of the things I did was to run the battery ground cable directly to a starter motor mounting bolt. I'd have to go back and see if that actually helped. The reasoning is sound, though. A little resistance here, a little resistance there...when you're running a lot of amps, it makes a difference.
~Steven
Simi Valley, CA
