Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 10-21-2018, 07:01 PM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
Trouble Code C0899
I used my code reader after getting a check engine light and is says C0899 Device 1 Voltage Low.
Since then I have been running with my lights on since the batteries wouldnt previously charge. They do now.
Does anyone know what this code is and how to fix it?
Old 10-22-2018, 06:40 AM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: Trouble Code C0899
That code is an ABS code. Its sets anytime the battery voltage is below 9 V for 100ms in the EBCM(electronic brake control module).
That code will not turn the check engine lamp on.
You can't fix that code. You will have to fix the charging/battery issue. The code will clear itself after 100 consecutive drive cycles.
You can also clear that code with your scanner.
95 S_Trucker is offline   Reply With Quote
Old 10-22-2018, 09:45 AM   #3
The Rocknrod
Moderator
Thanks S_Trucker, there's the issue, how to find the problem. I will try clearing it with the scanner.
Old 11-09-2018, 11:16 AM   #4
The Rocknrod
Moderator
So my #2 Battery is dead wont take a charge. Could that be it?
Old 11-09-2018, 07:37 PM   #5
62chevy302
hillbilly
62chevy302's Avatar
Yes. These new vehicles throw all kinds of codes when the battery gets low.
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 12-21-2018, 10:41 AM   #6
The Rocknrod
Moderator
Strange, I charged both the batteries, cleaned the terms, cleaned the grounds I could find (on the firewall). I cleared the codes last month about the ninth or tenth. The codes haven't came back (so far). Been checking the code reader for history. Nothing. Thanks for the help guys. Supposed to go on the road for a new job soon, before that happens I will install both new batteries just to make sure.
