Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-26-2014, 11:35 PM   #1
BigDan3131
BigDan3131's Avatar
Question 60-66 4x4's
I've been thinking that once I finish my turbo/4.8L setup in my 65 2 wheel drive that maybe buying a 65 4x4 Suburban is something I should have.
What I want to know is how strong are the front and rear ends in the Suburbans and were the early ones also available in 3/4 ton like the trucks? If I were to do another LS type swap in it and added a 4L80E should I keep the stock transfer case or upgrade to something newer?
I have no intention of doing any serious off-roading but for one of those backroad trips to a lake or driving in the snow when I need it. I'll just run the biggest tires that fit without mods, so something in a 31"?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 02-28-2014, 10:29 AM   #2
swamp rat
swamp rat's Avatar
Re: 60-66 4x4's
D44's should be fine for what you describe, but you should consider upgrading to an open knuckle version if the burb has a closed knuckle. if you want disks up front i think they were standard equip at about 1970 or 71
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-03-2014, 05:13 PM   #3
argonaut
argonaut's Avatar
Re: 60-66 4x4's
Something in the 31" to 33" range should fit a stock k10 or k20 sub.
The stock transfer case will be a divorced t221. They are a strong unit, if maintained correctly. The gears in them are cut pretty straight so they tend to have more gear whine than more modern units.
As was said stock axles are fine and even power drums would be fine if you aren't towing a heavy load or driving fast on the open road.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
