12-28-2015, 06:15 PM | #1 |
93 dually brake lines
Hello everyone,
Does anyone know of a place that sells prebent brake lines to fit 1993 CC Dually? I have found some for the rear axle only. But I can't find any for the front or down the frame. I did find one place that would make them if I sent them my old ones. There is a guy on eBay that has them for a 94 and says they won't fit a 93. What is the difference? Thanks all!
1993 Chevy C3500 Crew Cab Dually 1989 Cheyenne C1500 |
12-28-2015, 11:15 PM | #2 |
Rollin' Old Skool
Re: 93 dually brake lines
If you haven't yet, you might check with Classic Tube or Inline Tube.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
12-29-2015, 12:07 AM | #3 |
Classic Tube told me that if I send my old ones, that they can make me new ones.
12-31-2015, 07:29 PM | #4 |
Just asking: are you needing to replace the lines because they are currently leaking or are they "crusty" to the point you fear they will leak? I had to replace the front to rear lines on a 93 C1500 extended cab that spent to many winters in Ohio and I was able to use a couple of straight lengths of brake tubing from NAPA and my tubing bender and springs and followed the factory routing. Used different lengths of tubing so I didn't have to cut any of the tubing so I did not have to test my flaring skills.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
12-31-2015, 07:46 PM | #5 |
I live in SW ohio and this truck has been sitting in a gravel lot for 6 years. I'm wanting to replace all the brake components to make sure it is safe and reliable.
I can get a coil of stainless steel and make up the lines, but I hate making flares. And usually the factory fits so nicely I did find one kit that will do the rear axle but that's all.
01-06-2016, 07:01 AM | #6 |
Call a GM dealer parts department with VIN number. GM has brake line kits for the newer body style trucks. May have a listing for yours, worth a shot. Not bad price either, I pay between 130 to 160 for line for newer trucks.
04 Yukon XL 2500 w/ Quadrasteer 61 Chevy C60, 261 inline six 86 Chevy C20 2wd, Banks 6.2 05 GMC Sierra 2500hd Duramax |
01-08-2016, 03:24 PM | #7 |
Okay... I will
They did have lines for my 96 suburban. ... so maybe Thanks
