Well, Whoop-dee-do!
![]() Join Date: Mar 2003
Are these '72 Big block perches?
Found these cheap- I know they are worth some coin if they really are for the '72 only BB.
Can anyone ID without a doubt? I don't want to spring for them if they are '73- up.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD ![]() '72 K20 500 Cad/TH400/NP205 SOLD ![]() '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car ![]() |
Member #1049
Re: Are these '72 Big block perches?
yes they are the 72 towers! Here's is a couple of picture of a set I had.
hard to tell from your picture, but 73 up the holes are further apart in relation to the center rib. you need to get a pic. of the top view, also check to see if they have the clam shells to go with them. hope it worksout that they are 72 mounts as you can turn a few bucks on them if they are.
The tell tale sign is the humps, on the top rail part, 72 only have one hump and the 73 and ups have two humps (bumps if you will). So those are the 72 only's.
Well, Whoop-dee-do!
I told the guy I wanted them, might get them tomorrow night. Aren't the clamshells the same as ho- hum 73- up parts? If so, I can find those by the dump truck load
![]() Thanks for the help everyone ![]()
![]() Join Date: Apr 2005
Here's everything bolted together. They're for sale if anyone needs them.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Yeah the clamshells are all the same, if you find an old set, energy suspension sells a urethane bisket to replace the old rubber part, just seperate the clamshell (riveted together usually) and install it, sweet find!!
BTW HARTROD how much?? |
Well, Whoop-dee-do!
Got 'em. Both are stamped Demco, one numbered 757, the other 758. GM must of had an outside vendor for them?
#9 | |
Posted via Mobile Device |
