Old 06-25-2019, 02:54 PM   #1
Jeepwm69
Front brake dragging, 83 GMC
Truck is an 83 GMC, not driven much (@38K miles on it). Last week while in town I noticed the left front brake was dragging.
Given the age and what I found nosing around here, figure it's time to replace the rubber lines, and probably do calipers, pads, and maybe rotors at the same time.
AC Delco lines are cheap enough (@$12 each on Rockauto). What kind of calipers and pads do yall recommend? Looks like Delco sells a caliper/hardware/semi metallic pad set, but from what I've heard Delco isn't what it used to be, and these might just be the same crap Chinese parts in a fancy Delco box.
Suggestions?
Jeepwm69 is offline   Reply With Quote
Old 06-25-2019, 05:33 PM   #2
SCOTI
SCOTI's Avatar
Re: Front brake dragging, 83 GMC
Suggestions?
Buy your parts @ a local place that has a warranty on your purchase. No reason to purchase online for wearable items unless you're just looking @ initial purchase price.
For brake stuff, I like Raybestos & Wagner products & use them when possible. Otherwise, house brand w/the best warranty offered.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-26-2019, 11:13 AM   #3
truckin 79
I have been wanting to change my rubber hoses on truck but man do those look like a real pain to get to. I am putting this off as long as I can.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 06-26-2019, 01:13 PM   #4
SCOTI
SCOTI's Avatar
On a 'Squarebody', they're actually not too bad. Banjo fitting @ the caliper & bulkhead fitting @ the frame. Both are pretty accessible.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-26-2019, 03:49 PM   #5
mongocanfly
mongocanfly's Avatar
And if you decide to change the hoses be sure to use a proportional valve centering tool before you start bleeding brakes...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-27-2019, 10:23 AM   #6
Jeepwm69
Ah, so these trucks have the same type proportioning valve as my Jeep CJ's.
Good to know. Thanks for that info.
Old 06-27-2019, 12:14 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
And remember there are two different width rotors available for these trucks.
1-1/4” hd rotors and the light duty 1” rotors.
Calipers and bearings are also different.
Keith
Convert to disc brakes.
Old 06-27-2019, 04:38 PM   #8
Jeepwm69
I've noticed that most calipers say they're for 11" by 2" rotors OR the regular rotors.
Does that mean heavy duty calipers will fit all rotors, but light duty calipers will not fit the HD rotors?
Old 06-27-2019, 05:25 PM   #9
lolife99
lolife99's Avatar
No.
HD calipers only fit the 1-1/4” rotors.
Calipers have to match the rotors.
Rotors have to match the spindles.
And there’s 2 different spindles also.
No such thing as a 2” wide rotor.
Keith
Old 06-28-2019, 08:53 AM   #10
hatzie
Moderator
hatzie's Avatar
Likely it's made by the same supplier if not the exact same part.
AMC seemed to use the same parts as the big three in a lot of places. They were operating on a shoestring budget for several decades before they went under.
The 258 in my Eagle wagon used Ford Duraspark ignition parts and a Carter BBD carburetor that many folks swapped out for the Motorcraft 2100 or 2150. The BBD was used on many Chryslers.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-28-2019, 12:16 PM   #11
Jeepwm69
Yeah I have 2100's on two of my three CJ's (the Scrambler only has 5K miles on it so it still has the BBD).
I used a hotter coil and bigger cap/rotor on my Duraspark ignitions on mine. https://www.jeep-cj.com/forums/f2/te...e-11416-print/
I really like those Eagle rigs. Used to be everywhere and cheap, but looks like they're becoming a niche collector car now.
Old 06-28-2019, 12:18 PM   #12
Jeepwm69
No.
I was attempting to interpret how the calipers are listed.
ACDELCO 18R640 {#18035829} Professional; Non-Coated, Includes: Semi-Metallic Pads and Hardware; Reman. Info
FitsFront Left; with 11-5/32in x 2-3/4in Brakes
OrFront Left; Heavy Duty System; w/ 11" X 2" Brakes
ACDELCO 18R639 {#18035828} Professional; Non-Coated, Includes: Semi-Metallic Pads and Hardware; Reman. Info
FitsFront Right; with 11-5/32in x 2-3/4in Brakes
OrFront Right; Heavy Duty System; w/ 11" X 2" Brakes
ACDELCO 18R623 {#18035812, 18R737} Professional; Non-Coated, Includes: Semi-Metallic Pads and Hardware; Reman. Info One of our most popular parts
Front Right; Standard System; w/ 11" X 2" Brakes
Old 06-28-2019, 02:05 PM   #13
lolife99
lolife99's Avatar
The 11x2-3/4 and 11x2 refers to the rear brake shoe size on those vehicles.
Go out to your truck and measure your rotor width first.
Per RockAuto,...
It looks like 18FR623 and 18FR624 are for the light duty 1" rotors.
And 18FR639 and 18FR640 are for the HD 1-1/4" rotors.
Keith
Old 06-28-2019, 02:14 PM   #14
lolife99
lolife99's Avatar
Look at this thread also:
http://67-72chevytrucks.com/vboard/s...d.php?t=209390
A lot of parts stores show JB3 or JB5 when referring to brake parts,...
QUOTE:
JB3 is the 1" thick rotors
JB5 is the 1.25" thick rotors
Keith
Old 07-01-2019, 01:34 PM   #15
Jeepwm69
Thanks! Makes sense.
Old 07-01-2019, 02:03 PM   #16
smokehouse
the hardest part i had when doing the brakes was that stupid stamped steel nut to unscrew from the rubber brake line that sucked so bad i ended up cutting the rear metal brake line and going to the store and making a new metal line and then i used the stainless steel flex hoses the stopping power is so amazing now. I just did a complete brake job on my suburban and i had to find the correct master mine took the jb6. i know that the banjo bolt do not fit into both the 1" caliper and the 1.25 caliper they are different and the hole inside the bolt is way bigger on the 1.25 than the 1 inch. fyi
smokehouse is offline   Reply With Quote
