11-20-2017, 10:49 PM | #1 |
Cpp Frame mount gas tank
Has anyone installed a Cpp frame mount gas tank on there wood bed truck will they fit? the ad state 67-72 but it do not say if it is will fit wood bed floor. I have a 1969 c10 step side and have purchase a Cpp frame mount gas tank but notice LMC says there frame mount gas tank fit both wood and non wood floor wondering if Cpp works the same. my concern is how do it fit inside the bed any help would be great
11-21-2017, 01:29 AM | #2 |
Re: Cpp Frame mount gas tank
I installed the CPP tank in my 70 LWB metal floor bed. I'm posting the photos so you can see how the tanks fits in the frame. I don't think a wood floor would make much difference.
BTW - installation is a real PITA doing it by yourself. Get a friend to help with the final installation and bracket lineup. These photos were before I installed the RideTech suspension. The leaf springs are long gone. Yours might not have these brackets at the corners. I cut the brackets out of the corners to get a little extra clearance. Finished with the RideTech suspension.
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
11-21-2017, 02:23 AM | #3 |
Cruzzzn' Vet
With those leafs gone looks like you have room for a 12/15" wide rim.
Wonder if that trailing arm setup will work on an 83. |
11-21-2017, 02:34 AM | #4 | |
The angle on the photo is a little deceiving, there really isn't that much room.
11-21-2017, 09:53 AM | #5 |
One of my concern is the tank I have the spout comes up on the left side. in the bed will there be a problem with the floor strip are anything are everything align correctly
11-21-2017, 12:08 PM | #6 | |
CPP Tech/Order Line 714-522-2000
11-22-2017, 08:25 AM | #7 |
thanks for the diagram I don't thank the tank I have is correct I am trying to get cpp to let me return it without paying a 20% restocking fee I feel the add should state what type of bed the item fit because there different bed wood and steel floors for the 67-72 c10 my option
