06-21-2019, 06:32 AM | #1 |
Too low
Went too low on the 82 in the front ( hacked to much spring )
I put a 3 inch drop spindle in it and should of left it at that . Think I will start back at the stock spring and go from there AGAIN . What and where would be a good spring ???? Thanx |
06-21-2019, 07:31 AM | #2 |
Re: Too low
Find a set at scrap yard/Pick-n-pull. Personally I didn't like the ride of cut springs, especially if I took out more than a coil. Far as I know, springs from any 70-87 will work.
06-21-2019, 08:48 AM | #3 |
Re: Too low
Rock auto has springs for relatively cheap. If you are going to cut them, you might want to use heavy duty springs. This way the increased spring rate makes up for the lack of suspension travel. This way it takes the same force to bottom out the suspension.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
06-21-2019, 03:34 PM | #4 |
Re: Too low
2 spring cut on my 83 and it rides pretty nice, thought about adding 2" dropped spindles but that might be too low
06-21-2019, 04:18 PM | #5 |
driving is in my blood
Re: Too low
Lowered springs are like $100 why waste all this time instead of doing it right?
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
06-21-2019, 04:41 PM | #6 |
Re: Too low
2nd rockauto for new stock units . why waste time with used 30+ year old springs for the time and energy to swap them .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
06-22-2019, 09:35 PM | #7 |
Re: Too low
I like lighter duty C20 springs in dropped trucks
06-24-2019, 04:20 AM | #8 |
Diggin The SquareLife
Re: Too low
get hd springs an cut them
06-24-2019, 09:49 AM | #9 |
Re: Too low
Very interesting thing I noticed.
Compared coil springs between a 1982 C10 and C20 with a 350. Standard duty and heavy duty are the same between C10 and C20. Comparing 1970 coil springs, C10 heavy duty springs are the same as C20 regular duty springs.
06-24-2019, 07:36 PM | #10 |
Re: Too low
I wouldn't be surprised that this 82 has the original shocks on it , would a set of new good shocks help on the ride maybe !!!!
What's a good shock ??? for the front |
06-25-2019, 12:55 AM | #11 |
Re: Too low
Get some big block springs from rockauto and then cut one coil. I had worn out stock coils that I cut. Rode terrible and truck still had an obvious lean to the drivers side. Got some big block coils from rockauto and cut them. Rides way better and is level side to side now. I also put on some shorter bump stops and I couldn’t be happier.
This was all with my 2.5” spindles For shocks, I got summit drop shocks.
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
