Old 10-19-2020, 08:48 PM   #1
niner1962
Door bolts
How do you replace the threaded plate inside the front pillar?
niner1962 is offline   Reply With Quote
Old 10-20-2020, 07:34 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Door bolts
Cut sheetmetal.
Old 10-20-2020, 08:45 PM   #3
joesscamaro
Re: Door bolts
Yeah, I’m thinking you’ll have to get a cutting wheel and open them up that way. I’m guessing one of yours is stripped out?
joesscamaro is offline   Reply With Quote
Old 10-21-2020, 08:53 PM   #4
niner1962
Re: Door bolts
Actually the plate fell out on me!
Old 10-25-2020, 09:56 AM   #5
LT1 Burb
LT1 Burb's Avatar
Re: Door bolts
Cut the A pillar open, fix the plate and then reweld it back together.
LT1 Burb is offline   Reply With Quote
Old 10-25-2020, 11:17 AM   #6
raylube
raylube's Avatar
Re: Door bolts
One of my lower ones fell down also. If I remember correctly I think I used a flexible magnet to fish it up and then used a 90 degree pick to hold in place ant then used some small wire looped thru the bolt holes until I got one bolt started and then cut the wire. Good luck.
raylube is offline   Reply With Quote
