01-26-2020, 10:29 PM | #1 |
How does a 76 C10 get its main power feed
Hello
My Dad's old truck 1976 c10 stepside 454. When I turn the key I get nothing. The headlights don't come on with a good battery. I have several 71/72 Chevy blazers. They have a power lead coming off the positive cable that mounts to the junction box on the fender. From there it feeds the power to the truck. That would be where I would start if I had an issue like this with that truck. I see a junction box on the firewall of my dads truck. But there is not feed coming directly from the positive cable. So how do I start to trouble shoot and chase the problem. Any help is greatly appreciated. |
01-26-2020, 10:40 PM | #2 |
Re: How does a 76 C10 get its main power feed
You're on the right track with that junction box on the firewall. That should be receiving power via a wire that comes from the BATT stud on the starter solenoid.
01-26-2020, 10:45 PM | #3 |
Here's a link to forum member hatzie's shop manuals http://67-72chevytrucks.com/vboard/s...d.php?t=545416
01-26-2020, 10:55 PM | #4 |
Assuming it is wired per factory specs, the headlights should work without the key. Start with the simple things first. Batt ground should go to the alternator bracket and a ground strap from the passenger side back valve cover bolt to the cab(the strap is often missing). Possible the batt cables are rotted on the inside.
There should be a batt terminal in the cab fuse box that is hot all the time. Once you get power there, testing should go pretty fast. |
01-28-2020, 11:31 AM | #5 |
Moderator
The ground strap should run from one of the drilled and tapped accessory bracket holes in the RH cylinder head to the cab.
Look at the 1976 wiring diagrams. THE FOLLOWING IS 1976 SPECIFIC. In 1976 main power feeds (Circuit-2) is run through a fusible link on the BAT stud of the starter to the J-studs on the firewall next to the brake booster. Other years may have two or three fusible links 1976 has one. The Circuit-2 output runs from there to; the V & BAT terminals of the alternator. the Bulkhead plug on the firewall into the cab. Inside the 1976 cab you will find a splice that routes power to several points inside the cab. See the wiring diagrams for where. If the fusible link at the starter fails on a 1976 truck all power to the interior of the cab is shut off. You can check for power at the J-Studs on the firewall. If there's no power there you have a break between the J-Studs and the Starter BAT stud... Probably the fusible link. On a 1976 V8 the fusible link is 14 gauge attaching to a RED 10 gauge SXL power feed wire per the wiring diagrams. Circuit-2 power distribution varies a lot over the 1973-1991 model years. The above only applies to 1976. You should consult your model year wiring diagrams.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
