06-05-2017, 11:55 AM | #1 |
64 made2drag c10
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
06-05-2017, 12:04 PM | #2 |
Re: 64 made2drag c10
I've been asking car guys in the area if anyone knew of a 64-66 c10 really cheap. Ran into a guy who has one and knew of a parts truck. He said it was a 3/4 ton and thought it would be going to scrap soon due to nothing really left on it to part out. Come to find out, I knew the owner from swap meets and car cruises and he was excited that he finally found someone to show it some appreciation. I basically bought the door and got the rest for free. LOL. He says no hurry to pick it up and haul it home, so all I have are pics at the moment. He said it was a 64...the vin in the door opening above the door hatch is in the 64 only spot. I was so excited I didn't even look or take a pic of the vin.
06-05-2017, 12:07 PM | #3 |
Needless to say, I will be accruing parts over the next couple of years in order to put this one together. Plans will be a 5 lug disc conversion with a 5/6 drop and shortening the frame and most likely making it a rough driver. 350/3 speed or might do an auto. Wont be anytime soon though. Check back in a few years! LOL
06-05-2017, 04:38 PM | #4 |
With tires in that shape it is definitely made to drag. Sorry I couldn't resist.
06-06-2017, 12:16 AM | #5 |
60-66 Nut
That is definitely a project but I have seen people start with worse.
06-06-2017, 09:42 AM | #6 |
LOL, I like that! When I pick it up, the dude says he can use his forklift to place it on the car trailer! When it's home, we will have to tie it to a tree and yank it off. LOL
06-06-2017, 09:50 AM | #7 | |
The reason I liked this truck is: No one wanted it because it was long bed and 8 lug. So I got it really cheap. I'm going to do a ball joint out 5 lug disc conversion anyway. Its ready for wire brushing and painting the frame. I can do a new bumper and grille and new fleet bedsides and find stock hood and clip pieces. The cab seems to be in really good shape for being 53 years old. 2 cab corners and a rocker and maybe some floor patches... If it were a stock stepper with a straight 6 and 6 lug, it would be changed anyway. Less work, really. Im happy!
06-07-2017, 01:04 AM | #8 |
60-66 Nut
I don't think you can press in a lower balljoint that will accept a 1/2 ton dropped spindle. The C20 lower control arms as well as the entire front crossmember are different than the C10 components. I have never tried a C10 balljoint in a C20 lower control arm, but I am pretty sure the hole in the control arm is too big.
06-07-2017, 09:10 AM | #9 | |
06-07-2017, 09:13 AM | #10 |
I cant wait to start on this truck... seriously don't see it happening til after I get my 69 drivable. I really just need a big chunk of time to put it together.
06-08-2017, 01:15 AM | #11 |
60-66 Nut
On the '63-'66 C20/30 trucks you can not simply change the control arms, you have to change the crossmember as well. This is due to the C20/30 lower control arm shafts are flat and not round. There are no saddles on the crossmember to accept a round control arm shaft.
06-08-2017, 09:21 AM | #12 | |
06-08-2017, 09:23 AM | #13 |
And seeing your post.... it just hit me its a c20... any other differences between the c20 and c10 once the crossmember is changed and the rear end and springs are changed?
06-08-2017, 09:28 AM | #14 |
Also, can anyone tell from the pics if that is a fleetside bed front panel? The poison ivy kept me from walking around the truck and the dude had some many cars and trucks that distracted me away after I shook hands on the truck, knowing I was 100% buying it. The cab and frame looked excellent from where I stood.
06-09-2017, 12:00 AM | #15 | ||
60-66 Nut
Aside from the slightly thicker frame, the rear cab mounts are different and there are braces from the trailing arm crossmember over to the frame.
06-09-2017, 09:05 AM | #16 | |
06-09-2017, 04:42 PM | #17 |
I hope the PO gave you the key to the gas cap.......
Just kidding!
Everybody has to believe in something. I believe I'll have another beer. |
06-12-2017, 09:39 AM | #19 | |
Plus, just the front bed panel would cost me more than I bought everything for. Definitely getting fleet bedsides!
