Billet Specialties true trac , with supercharger?
Just doin a little research.
Does anybody know if the true trac serpentine setup for a small block Chevy will work with a Weiand 142 supercharger. Or if one of the March setups will work? I'm sure that a GM performance parts serpentine setup would work with a blower ,but I was just curious if any other setups would. Anybody got any pics?
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
Re: Billet Specialties true trac , with supercharger?
I would think that Weiand, March or Tru Trac would know.
![]() Join Date: Oct 2005
I used Concept One with a "long water pump" blower. the hitch you may run into (I did) was fitting the lower blower pulley into the serp pulley. They (Concept) machined a lower blower pulley for a very reasonable cost. If I remember correctly, I have a little more than a grand in my pulley setup (came with water pump, 100A alt, and compressor)
That said, I sure to like the others (like Billet Sp & Vintage) that are more compact and only use one belt......they are alot more coin though.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Only a grand! I figured you spent alot more than that on your setup. I may look into Concept one ,for that price. Thanks for the info.
Anybody else?
#5 | |
I Have a couple questions. I have a nova with a 383 and on top a weiand 142 but I have trouble with temperature. I Can't drive it for more then 10 minutes without getting the temperature to 200. I Have a aluminum radiator my distributor doesn't have advance no msd retardant It has a msd6al. It has a 350 trans and a 4.11 rear diff and a regular stall I have used electrical fan and a regular also what do you guy think? Any help is welcome. Thanks.
