Old 06-17-2015, 11:19 AM   #1
57larry
Rear disc brake kit confusion
I did a search and boy am I confused. I have a 68 1/2 ton with a 5 lug rear. Is there any kit out there for rear disc brakes that you don't have to pull the axles? Maybe just cut the backing plate off. Could someone list all the parts I'll need to complete this swap. Thank you, Larry
57larry is offline   Reply With Quote
Old 06-17-2015, 12:19 PM   #2
70blackfish
Re: Rear disc brake kit confusion
pulling the axles out is not a big deal...look into it
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 06-17-2015, 01:10 PM   #3
Hart_Rod
Hart_Rod's Avatar
You don't have to remove your axles to install the CPP kit.
Hart_Rod is offline   Reply With Quote
Old 06-17-2015, 05:16 PM   #4
Tinkermc
pulling the axles is easy but not needed in a lot of cases. It would be a good time to pull and replace the seals also.
Tinkermc is offline   Reply With Quote
Old 06-17-2015, 05:45 PM   #5
davepl
davepl's Avatar
You likely only need to pull the axles on C-clip rear ends. Which could be the case on a half ton, but the HD ones are all floating axles.
There may be ways to install that kit, as mentioned above, without pulling them. But the Cadillac rotor system thats in a lot of kits does require it.
Either way the drum backing plate has to come off, right? Does it get cut off?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-18-2015, 11:41 AM   #6
Fitz
To change from drum to disc brakes you need to remove the backing plate for the drum brake setup. It will not fit over the axle flange. It's a bit easier to just remove the axles but you might be able to cut the backing plate off with a 3 in grinder and a cut-off wheel. It's a forging, though, so expect a tough job. Once that is done, the CPP disc kit bolts tight on. No need to remove the axles to get it assembled correctly once the backing plate has been removed..
Fitz is offline   Reply With Quote
Old 06-18-2015, 06:43 PM   #7
57larry
thanks for all the help guys. think I'm going to go with Scarebird's kit
Old 06-18-2015, 07:00 PM   #8
Fitz
It will work!
Old 06-25-2015, 12:40 AM   #9
57larry
just heard back from scarebird. he doesn't offer a rear disc brake kit for our 67-72 trucks.
anybody else have a kit besides cpp & captainfab?
Old 06-25-2015, 07:14 AM   #10
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Rear disc brake kit confusion
I don't know how anyone can put the CPP kit on a rear truck axle without removing the axles unless they started fresh with no drums. I had to remove mine and put new seals on it while I had it out. I did the bearing a few years ago and seals. The backing plate has to come off of the rear end to mount the disc brake bracket. It will not slide over the flange.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 06-27-2015, 12:17 AM   #11
57larry
I'm in LA for 2 weeks of vacation. I stopped in CPP today and bought the rear disc brake set up. The 2 counter guys were very helpful and friendly
