04-21-2023, 01:24 PM | #1 |
Bad new ICM?
Hi all,
My truck died 6 months ago and I was too busy to fix it. turned out it was the Ignition Control Module. No fire, no fuel. I replaced with with a GM original. now she is ROUGH! Hard to start. Idles rough. Backfires. Hesitates. I put in fresh fuel. Same problem. Bad ICM or should I look at something else? Yes. I did put the thermal paste on the new ICM. Thanks 1990 350 R1500
1990 suburban r1500 k 350 2wd |
04-23-2023, 04:07 AM | #2 |
Just here to tinker
Re: Bad new ICM?
Did you reset timing? Perhaps something changed there.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
04-24-2023, 06:20 PM | #3 |
Re: Bad new ICM?
I did not.
I need to get a new one. Last one broke. any recommendations?
04-26-2023, 01:05 PM | #4 |
Just here to tinker
Re: Bad new ICM?
You mean your timing light broke? Any brand is fine I’m sure. I like the ones that can advance in degrees to check total timing.
04-26-2023, 05:39 PM | #5 | |
Re: Bad new ICM?
I went through a hand full of modules inside the distributor. most are chinese junk with little or no heat sink. Now i keep an extra in my glove box |
