11-03-2019, 10:40 AM | #1 |
Used painless circuit boss harnesses
I have a couple of used painless harnesses.
One has longer wires, one has short. I figure between the 2 it makes it easy to swap pins around and configure as needed. These are actually made by Packard, so the fuse holder pins are available new also. Hella and others make the relay pins. The fuse holders can be attached to each other so you can stack them up. $30 shipped in the lower 48, $20 local
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
