Old 08-01-2003, 02:01 PM   #1
krue
Designated A-hole!
krue's Avatar
Pros and cons of LT1?
I know where a LT1 from a wrecked camaro with tranny and wires, computer etc can be had for $1500 and I was wondering what else I would need to put it in my 70, and generally what the good and bad points of the swap are.
PS I could use some good arguments to chisel the money out of my wife while ya'll are at it!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 08-01-2003, 04:07 PM   #2
Charlie Coleman
Charlie Coleman's Avatar
I can't think of any cons. You will need to convert to an electric fuel pump.....but most everything is simple, just time consuming.
Sell the wife on the fuel mileage, better for the environment (less polution), less tune ups, and above all, it's just cooler than the neighbors project.
Good luck!
Charlie Coleman is offline   Reply With Quote
Old 08-01-2003, 05:59 PM   #3
GasHog396
As the owner of a LT-1 powered '97 Trans Am, I can give you a few of the problems I have encountered over the years and some suggestions. The intake manifold has a tendency to leak oil. It's not too hard to fix once the engine is out of the car. The Opti-Spark unit is expensive to replace (over $100). Just keep it dry, as water seems to make them go out. Mine has been fine so far, but it looks like they usually give up the ghost at around 120k miles on average. Go for a 96 or 97 style unit if it needs to be replaced. Water pumps last about 70k miles on average. They are about $135 at Auto Zone with a lifetime warrantee. Electric fans will be needed, as there is no way to install a belt driven unit. Try to get the radiator and fans from the Camaro and install them as a unit into the truck. A F-body LT-1 will require premium gas. PCM (computer) modifications will probably be need to make the engine run correctly, and to make the trans shift right (if it is an auto trans). F-bodies use an electrical speedometer, so a conversion unit will be needed for the truck. I would personally install a 160 degree thermostat to make it run cooler, expecially in the summer. My T/A will get to 220 in traffic with the stock 180 thermostat, but will only get to 180 with the cooler thermostat. Just make sure to use a thermostat designed for the reverse flow LT-1. Unless you are really good with wiring, save yourself some grief and pop for a wiring harness from a company like Painless. A VATS (security feature) by-pass module or a custom PCM reflash will be needed. The cat converters will need to be retained if you live in a part of the country that has emissions testing as you may have to meet the emission requirements for that year engine, not the truck it is in. Of coarse, it all depends on who you know. As a side note, if you don't want to get into all of this, you could always resell the motor at a profit. $1500 is cheap if the mileage isn't too high. These engines/trans combos usually start around $2500 used. One really nice thing about this combo, is you would probably get 20+ MPH on the highway, as long as the rear end ratio is reasonable. Gotta love that OD trans.
'67 1/2 Ton Short Bed / 396 cid / AC w-R134a / 5 Lug Leaf spring rear axel / 5 Lug Frt Disk Brake Conversion
'97 Trans Am - Black / LT-1 / K&N FIPK Cold Air Kit / Hooker Cat-Back Exhaust / 160 Thermostat
'02 Buick Regal GS / Bone Stock
GasHog396 is offline   Reply With Quote
Old 08-01-2003, 06:28 PM   #4
krue
Designated A-hole!
krue's Avatar
I have around a 307 rear gear. The car is a wrecked 97 Camaro, I just checked, I can get the whole car for $1600. I don't know how many miles, but it's been sitting for 2 years now.
www.daveramsey.com
Old 08-01-2003, 08:29 PM   #5
GasHog396
A 3.08 rear would put you at about 1400 RPM +/-100 at 70 MPH. I don't like the fact that the engine has sat around for 2 years, but if it looks 'clean' it's probably okay. (clean as in clean oil, trans fluid not burnt and clear, etc..) 97s used OBD2 diagonistics, so try to fine a code scanner and see if the PCM threw any codes. You will have to hook up a battery to do that. If you have the key, turn the ignition to 'run' to turn on the odometer (if its digital like mine). Any front end damage should be looked at closely, as it could have pushed the radiator back into the engine, MAF, throttle body, etc.. $1600 sounds like a great price for the entire car. I wish I could find a deal like that. I would love to stroke a LT-1 for my T/A. There's just no replacement for displacement.
Old 08-02-2003, 05:16 AM   #6
jay-dawg
chevelito
jay-dawg's Avatar
good info here:
http://67-72chevytrucks.com/vboard/s...threadid=52057
good luck
jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 08-02-2003, 05:09 PM   #7
krue
Designated A-hole!
krue's Avatar
ttt
www.daveramsey.com
Old 08-03-2003, 02:03 AM   #8
jcueckert13
jcueckert13's Avatar
the only con i can think of is instaling all the wiring and sensors
1990 subaru legcy (daily driver)
1987 Toyota 4runner (weekend toy)
1968 C30 flatbed dually
1970 C10 longbed stepside (in pieces)
1976 Dodge Dart
1963 Dodge Dart
jcueckert13 is offline   Reply With Quote
Old 08-03-2003, 09:04 PM   #9
krue
Designated A-hole!
krue's Avatar
If he still has it on the 15th I am gonna go for it!
www.daveramsey.com
